Injector Question
OK someone answer the tie rod question?!?!
Also I badly need help with this part, I ordered the tension rod kit from Blackdragon, and it shows to fit 79-83, but I just found it on the Z store and they show it only fits 70-78?!?!?!
http://www.thezstore.com/page/TZS/PROD/PSDC10/23-4190
A) Will this work on my 83t?
B) Has anyone installed this? If so can you please post a picture.
That's for the 70-78 S30... not the right part for your 280zx. Go to AutoZone / Checker / your local parts store.
To take off the tie rods:
-Loosen the tie rod nut on the steering nuckle until the top of the bolt is flush w/ the nut. Give it a couple dead on whacks w/ a hammer & it should pop out... if not, use a ball joint removing fork.
-Once that is disconnected, mark the inside threads where the tie rods screw on (so you can keep the alignment) with some white out. Put a wrench on the tie rod & nut... crank them loose.
-Remove tie rod
-Install is easy.
-Remove tie rod
-Install is easy.
OK so the book isn't misleading. Interesting, thank you.
So this page is wrong? Or I am a dumb ***?
http://www.blackdragonauto.com/icatalog/z/0045.html
I spoke with Black Dragon this morning, and they were very adamant on that kit working with the 83?
No not yet still looking.
Not to change the subject, but I want to vent for a second.
I ordered parts from www.rockauto.com a week ago, and they came into day. Here is what I ordered.
2 different types of wheel bearings for the rear x2
Cap
Rotor
Ball joints
Valve Cover Gasket
Here is what I recieved.
2 different types bearings that don't go to a Z
Cap with 8 plugs
two different types of ball joints
and a bent valve cover gaket
Funny...........
Cap
Rotor
Ball joints
Valve Cover Gasket
Cap with 8 plugs
Funny...........
Most junk yards will sell them for $20-$50.
