Ignition control module help
Old Feb 10, 2023 | 06:07 PM
ZTommy's Avatar
Hi everyone, quick question so been having problems with car staying running when it gets warm thought I'd try new icm, so I have 83 non turbo I u did the two screws, first question how do you disconnect the wires that go into distributor, on box or inside distributor? Second question on the back of the old box it's covered in I assume electric white grease. Is this necessary? Sorry first time working on this car. Thanks and hello to all
Old Feb 11, 2023 | 06:06 AM
Kickstand80's Avatar
The red and green wires have spade connectors on them and the wires will just pull off. The re-positioning of the wires needs to be correct so pay attention as to where the red is and where the green is. If you still have the rubber boot that goes between the ICM and the distributor it has "red" and "green" printed on where the wires go.
Here is a great source for distributor repair and rebuild. Scroll way down to see how the pickup coil is attached to the ICM.
AtlanticZ 280zx Matchbox Distributor Rebuild Guide
Old Feb 11, 2023 | 02:23 PM
ZTommy's Avatar
Thank you I'll give it a try , does that grease or cooling stuff need to be on the back or ?
Old Feb 11, 2023 | 02:50 PM
I have never put it on. the heat transfer surface is pretty small confined to the mounting screws. I think the air gap is what keeps it cool
H3lic
Jul 31, 2017 05:49 PM
SHADY280
May 16, 2006 05:30 PM
newb81280zx
Mar 5, 2005 11:38 PM
rifleman502
Dec 17, 2004 10:13 PM
rifleman502
Aug 1, 2004 09:17 PM
