Ignition Coil
Old May 26, 2010 | 03:07 PM
83Turbo's Avatar
Angry Ignition Coil
Ok, my Ignition Coils keep frying on me. I have bought a new Distributor Transistor Unit and that fixed the problem. After I installed it, i started it and let it idle for a while, and out of nowhere, it died. I checked the Ignition Coil and sure enough it was fried. What keeps ruining my Ignition Coils or what is making the Distributor Transistor Unit ruin the Ignition Coils?
Old May 26, 2010 | 05:39 PM
How do you know your coil is "fried"? What tests did you do?
Old May 26, 2010 | 06:41 PM
83Turbo's Avatar
I checked the voltage and I was getting 12 volts to both the Possitive and Negative sides of the Ignition Coil
Old May 26, 2010 | 06:49 PM
BlueKitsune's Avatar
Intrawebz Wizard
Both sides had 12V when checked with a ground?
Old May 26, 2010 | 07:22 PM
83Turbo's Avatar
Yep, both sides did when checked with a ground
Old May 28, 2010 | 03:52 PM
83Turbo's Avatar
I take it I've stumped some people with this one
Old May 28, 2010 | 03:59 PM
Intrawebz Wizard
I have no idea unless you like have an MSD system and have it hooked up wrong.
Old May 28, 2010 | 07:07 PM
83Turbo's Avatar
it has the stock ignition system on it
Old May 28, 2010 | 07:10 PM
Intrawebz Wizard
Tho only thing I can saw is check all your wires for breaks and shorts and make sure that everything in the circuit is working. Other then that I have no idea
Old May 30, 2010 | 03:40 AM
duckyz's Avatar
Is the resistor connected?
Old May 31, 2010 | 09:21 AM
83Turbo's Avatar
Are you talking about the resistor on the right side of the Distributor Transistor Unit?
n00blar
Jun 3, 2008 12:26 AM
duowing
Sep 20, 2007 12:45 PM
21Nemesis
Dec 7, 2006 12:13 PM
Aphrodite
Dec 31, 2005 12:19 PM
MetalTear17
Aug 22, 2004 08:46 AM
