I suck as a mechanic
Old Oct 26, 2015 | 03:17 PM
gm1697's Avatar
Alright so I'm new here, but not new to being a mechanic.
I have a heavily modded truck but this is my first car, and first import.
I have a 1983 280x non turbo.
It's not getting spark.
I've replaced the following
-plugs
-wires
-coil
-rotor
-cap
-ICM
So I'm stumped. Next I plan on doing the AFM breakdown/cleaning. And I also figure I should pop open the ECU and check for burnt resistors. But basically all my masculinity and pride has been lost.
Anything else I should check for??
Old Oct 26, 2015 | 04:20 PM
rogerz's Avatar
Grumpy & Helpful
probably be good to find out if your coil is good. Oil has nothing to do with sparks. if it is running good i wouldn't mess with the AFM. Many who tried have found nothing but a rocky road ahead.
Old Oct 26, 2015 | 05:23 PM
gm1697's Avatar
I meant coil, not oil oops. Edited original post
Old Oct 26, 2015 | 08:42 PM
If it's not sparking, it's not getting power. Check fusible links.
Old Oct 27, 2015 | 06:14 PM
gm1697's Avatar
Visibly the fusible links and connections look okay. Is there a way to judge them beyond this?
Old Oct 27, 2015 | 06:57 PM
ken99's Avatar
Check them for continuity with a multi-meter. Appearance can be deceiving.
Old Oct 28, 2015 | 09:25 PM
gm1697's Avatar
there is continuity on all fusible links
also followed all the steps listed in the FSM for ignition system
it seems I've pinpointed it to being a faulty pickup coil in the distributor.
is this a common piece to go bad? And would this cause a "no spark" condition?
Zrolimit
Jan 7, 2007 11:56 AM
rgus30
Oct 10, 2006 11:52 AM
thxone
Sep 7, 2006 07:14 PM
RodMoyes
17
Oct 17, 2005 07:11 PM
brian83zxt
Feb 27, 2001 05:00 PM
