I got my '83 to start!!
Old Jan 28, 2007 | 05:54 PM
I am so close, but I actually got to hear it run for a few seconds!! And it was on fuel, not anything else. So I am taking a little break, and then going out there, and check the plugs, and see how they are. I am pretty sure tomorrow, or this week. My '83 will be running on his own power for more than a few seconds. And then some, he he
Old Jan 28, 2007 | 06:18 PM
n00blar's Avatar
Nice, good job Wildman!
Old Jan 28, 2007 | 06:22 PM
hmmm why only a few seconds? incase it comes gown to it im just gonna say it now. if you cant get the car to run for more than a few seconds be sure you got the right AFM. there are 2 dif styles i believe and with the wrong one it will run for a few seconds and die everytime... just a heads up if your suddenly have a huge problem like that.. but for now... AWSOME.... time to shoot for continuous running haha.
Old Jan 28, 2007 | 06:33 PM
fuel pump? good work anyhoo wildman. i know you can get him going.
Old Jan 28, 2007 | 06:46 PM
Yeah the fuel pump is working fine, after I swapped it for another one. Funny thing is the one that works came off my '82. I am thinking the AFM is shot, Will investigate some more, and let you know. And thanks for the comments so far.
Old Jan 28, 2007 | 06:55 PM
duowing's Avatar
NisTuner
Did it start up, kinda run for a moment then die? If so, did you try turning it over again? My Z was doing this but would run after turning it over again when the O2 sensor was dead.
Old Jan 28, 2007 | 07:50 PM
Well I put my NGK's I had on my '82. They were still decent, and I when I pulled the plugs out of the '83. They were fouled, so I am thinking the AFM, and possibly the throttle body is gummed up also. I will wait until tomorrow, and get some starter fluid for it. And I thought about using my good AFM, but I am afraid, because if I screw it up. I am screwed, and will have no vehicle to drive. I tried the AFM's I had lying around, but they all were the same result. It would run then die, and not restart. I also hear a clacking sort of sound when it it running. It is a horrible sound, and worries me. Any thoughts? I don't think it is inside the engine, maybe something is loose? What do you all think?
Old Jan 28, 2007 | 09:20 PM
skittle's Avatar
Taste My Rainbow
if worse comes to worse when i get my car back from that kid i have 4 afm's that might work for ya.
Old Jan 28, 2007 | 10:43 PM
Sounds good skittle, thanks man. Let me know, and I will keep all of you updated. Will work on it more tomorrow probably.
Old Jan 29, 2007 | 04:25 AM
FubarI33t's Avatar
Wild. I had this problem with my car. The Main reason my car would not run over the year i tried to make it. was the Oil Pump/Dizzy shaft. it was off one notch. It would start. spudder and then die.
Old Feb 1, 2007 | 02:31 AM
Well I took the risk the other day, and used my good AFM. At first, it started right up, ran for a few seconds, then died. When I tried to restart it, it would actually try to catch, but wouldn't start. Anyway I have decided to get a bucket of carb cleaner, with the basket in it. And soak the bottom of the fuel injectors, cold start valve, and whatever else has fuel running through it. I even thought about soaking the EGR valve, because I am sure it is plugged up. That way doing all that, I save myself some grief. And eliminate more problems, that would later develope.
I want to get this Z running badly. But I want to take my time, and do it where it will run like a top. And try not to hurry, which I really haven't been. Which is a good thing, anyway will keep you all posted.
Old Feb 1, 2007 | 06:48 AM
while you have the rail off, blow it out, or soak it if ya can. change the fuel filter yet? you prolly already did all the tune up stuff. and i cant stress enough aboot fresh gas, even if it is a pain to get out.
Old Feb 1, 2007 | 06:59 AM
skittle's Avatar
Taste My Rainbow
even check the pressure regulator, that can be bad as well
Old Feb 1, 2007 | 09:20 AM
theres 2 pallnet fuel rails on hybridz for the supra/dsm injectors... i think im gonna get one... exciting! lol
Old Feb 1, 2007 | 12:29 PM
Yeah I thought about using the JSK rail, when I put everything back together. As for the fuel filter, pretty much new and I checked it already. The fuel in the tank is not that old. I put it in not too long ago, after swapping the fuel tanks.(roughly 4 months ago, and only 5 gallons) I am also getting some Techron fuel system cleaner, after putting some more fuel in the tank. That stuff is amazing! I haven't really replaced all the tune-up parts. But they looked decent, and I did swap out the plugs, for some better ones. Just temporary, until I get it runnning, then I will buy all new tune-up parts. The fuel pressure regulator, I was thinking about also. Thanks guys for all the suggestions, will let you know more, as I progress.
Old Feb 1, 2007 | 12:38 PM
i tihnk my FPR is bad.. guy claimed it was even thought car seemed to run pretty well... i think im gettin me a pallnet rail this weekend... so maybe i can get an after market FPR for it... ill have to search around.
zcooks
Apr 11, 2016 06:36 AM
bongpogi
Aug 19, 2015 11:15 AM
moorebl
Apr 14, 2011 03:28 PM
bardabe
Sep 21, 2004 03:12 PM
