help with rust
Old Nov 14, 2005 | 09:48 PM
espi's Avatar
help with rust
ok actully how to get rid of it diy style.i have rust around the top of the windshield don't think it goes through and rust in other places near the glass any way of fixing this myself and it lasting.any advice will be graet thanks in advance
Old Nov 14, 2005 | 09:53 PM
007max's Avatar
From NY to AZ
punctuation ftw
Old Nov 14, 2005 | 10:45 PM
How much body work / grinding / welding / body filler experience do you have as of right now?
Old Nov 15, 2005 | 07:11 PM
espi's Avatar
in a short way none, but a quick study.
Old Nov 15, 2005 | 07:36 PM
Then I'd suggest using a spare parts car to learn on. No sense in screwing up your own car.
Or take it to a body shop.
Old Nov 15, 2005 | 08:19 PM
jfairladyz's Avatar
If you're good at picking up on stuff and can actually learn from your own mistakes and realize when you're doing something wrong without someone telling you then it's really not that difficult. The problem most people have with body work is not being able to resist the urge to cut corners. Body work, unless you're a professional with X amount of years under your belt, is a practice in patience and perserverance. It's not for everybody. Even if you've got the touch you've got to have the will power to stick with it and do it right. Rust is the worst. If there is even the slightest hint of rust left after a clean up job it WILL come back to haunt you. So make sure you get it all.
Old Nov 15, 2005 | 10:59 PM
Lost Vegaz's Avatar
If the rust spot goes into or under the window seal, pull the window out to. It can and will go under window seals.
Old Nov 16, 2005 | 06:50 AM
ain't that the truth no one wants to hear!
Old Nov 16, 2005 | 02:10 PM
espi's Avatar
yhanks for the advice
Old Nov 23, 2005 | 06:10 PM
BigEkak1941's Avatar
We had a small amount of rust on top by the crome strip that covers the windshield edge. I removed the trim and found that it went down furthor than I thought. The problem with rust it's like an iceburg you can only see a small portion. If you have a small grinding tool (dramal hand grinder) you can grind a little to see how far it has gone. However, like jfairladyz said, if you don't get all the rust it just comes back with a vengence. Good luck
ETHoward
14
May 12, 2015 01:03 PM
GOLDNZX
Feb 13, 2012 07:13 AM
PredatorZ
Jan 24, 2012 06:37 AM
master300zx
Apr 10, 2006 08:50 PM
Spak339
Apr 5, 2004 02:42 PM
