Help diagnose what went wrong
Old Aug 15, 2009 | 11:45 AM
thetremendousti's Avatar
w0rld's l0ngest m0t0rswap
oil in my water
Old Aug 15, 2009 | 11:49 AM
BlueKitsune's Avatar
Intrawebz Wizard
Congrats you blew a headgasket! Time to pull the head.
Old Aug 15, 2009 | 01:00 PM
how the f*** did you blow the head gasket?
Old Aug 15, 2009 | 02:02 PM
280zx2by2's Avatar
Haterade by da gallon!
he was waiting for vtec to kick in yO!!!!
Old Aug 15, 2009 | 02:34 PM
skib's Avatar
This facepalm's for you!
jesus it really is the world's longest motor swap
Old Aug 15, 2009 | 03:52 PM
i'm guessing its the head i bought used from pierre's Z last year is cracked. or maybe the block is. who ****ing knows all i know is that i am getting no mercy at all time for a rebuild even before i finish **** every****ing thing
Old Aug 15, 2009 | 03:56 PM
skib's Avatar
check and make sure its not warped
Old Aug 15, 2009 | 03:57 PM
okay 100 bucks for getting ****ed is understandable but i paid 250 and i paid a man
Old Aug 15, 2009 | 03:59 PM
skib's Avatar
is it a p90?
if its warped it can be milled flat again
Old Aug 15, 2009 | 04:01 PM
yeah how'd u know its p90 and how u know its warped and why didnt i know before i put it on and why now god
Old Aug 15, 2009 | 08:20 PM
venemoushorn's Avatar
Wow, bad luck! I guess we're doin the same job.
Old Aug 15, 2009 | 08:24 PM
Intrawebz Wizard
Why not make sure all the head bolts are TQed down right first?
Old Aug 15, 2009 | 09:02 PM
skib's Avatar
its a turbo motor
its just a guess, but normally when a HG goes for no apparent reason it tends to be a warped head
its not always obvious if your not looking for it
and why now god
hes smiting you for touching yourself at night
Old Aug 15, 2009 | 10:25 PM
Intrawebz Wizard
Doesnt help you had that Z dieseling before either...
Old Aug 15, 2009 | 11:03 PM
you think maybe that huge backfire i had helped screw it too? yeah i might as well make sure they're all torqued down, wouldn't that + gasket take care of any 1/1000th inch of warp?
Old Aug 15, 2009 | 11:20 PM
Intrawebz Wizard
That little of a warp? Ya
Old Aug 16, 2009 | 01:33 AM
skib's Avatar
you are using a decent torque wrench right?
Old Aug 17, 2009 | 12:53 PM
any head i buy i take to the machine shop. usually check it out for free. probably warped before you put it on. a backfire wont really warp a head. over heating does or usinge the wrong torque pattern or letting it sit to long on a non flat surface or not unbolting it in the right pattern or valves hitting pistons can do it.
Old Aug 17, 2009 | 01:03 PM
Buahhahhhaha!!!!
Old Sep 16, 2009 | 09:55 PM
So as you know I had my engine running until it patrick swayzed and got oil in the water, which is a mystery. Its all torn down now and this is what I'm looking at.
The head has passages where water COULD be flowing but the block doesn't even have passages for it to go! Nevermind the fact that the gasket blocks it off...
So what else could have gone wrong? The pistons are looking clean though and so is everything else. What else should I be looking for
Old Sep 16, 2009 | 10:11 PM
Did it overheat? (I can't remember... and you started a new thread instead of continuing your other).
The ports on the headgasket depend on which head / block combination you order it for. I've done more than a handful of L28 head jobs and found that some are made diff than others. Hell, my MLS headgasket from MSA didn't have the right ports, so I drilled them out after another head job. I haven't raced it since then to see how hot it will get under a heavy load, but running on the freeway in 100*+ is cooler than it used to be.
See my thread on that: https://www.zdriver.com/forums/showt...+gasket&page=2
Intrawebz Wizard
Why is this in OT?
Anyways You can get oil in your water though the timing chain cover gasket. not just the head
Old Sep 16, 2009 | 10:19 PM
Merged w/ previous thread & moved to correct location in S30 motor swap section.
Old Sep 17, 2009 | 09:43 AM
Fast240Z's Avatar
What brand headgasket are you using? In my experience, the Fel-Pro gaskets do not match perfectly with the L series motors, and I kept getting oil and water mix. I eventually went and sourced a Beck/Arnley gasket from Napa, and I haven't had that problem since.
Old Sep 17, 2009 | 10:22 AM
zenzee's Avatar
blown head gasket
I stand by fel pro gaskets been using them since 1985 and have many Z-friends and techs who swear by fel-pro gaskets. In my opinion the cyl-head is the problem until you do a professional pressure test and also for warpage....o/k.
