Heater does not shut off
Old May 6, 2009 | 09:06 AM
lts70's Avatar
On my 1982 280zx the heater does not shut off. My dad (previous owner) was using a pair of vice grips to shut off the flow to heater core to solve the problem. Has any one ran in to this? I would like to fix it corectly if possible
Old May 6, 2009 | 09:09 AM
E320zx? You mean 280ZX??? Yes... check the water **** (valve). And you can use the SEARCH feature as most of your questions have been asked & answered before.
Old May 6, 2009 | 09:54 AM
If you have a manual heater control system or the Auto Climate control then you need the replacement valve to be from the corresponding system.
Old May 6, 2009 | 12:40 PM
lts70's Avatar
I believe I have the Auto set up. I will check for sure when I get home. Where is this valve located, what do I have to remove to access it? This is what it looks like, right?
Old May 6, 2009 | 12:50 PM
Yep, that's it. Passenger side, above the tranny hump.
Old May 6, 2009 | 01:18 PM
I tried to replace hoses on that unit and it was a PAIN to get to.
As much work as it is, I highly suggest you remove your dash. Then carefully replace a few of those smaller vacuum hoses while you're in there.
zitupbaby
May 5, 2011 11:46 AM
drftrzx
Nov 8, 2008 08:04 PM
junkd85
Jan 7, 2008 09:45 AM
ihc300zxt.t.
May 8, 2006 05:02 PM
81 Black L28E
Jul 8, 2005 03:23 PM
