Fuel pump issue.
Old Apr 9, 2012 | 02:42 AM
ryn004's Avatar
Fuel pump issue.
I went to start my 280zx the other day but only starts for a second, then starves with fuel and goes off. Usually the fuel pump goes on when the ignition is on, but this is not happening. The fuel pump is good because I connected it straight to the battery to test it. And the fuses under the dashboard on the driver side seem all intact.
Are there any other set of fuses? What else can I check?
Old Apr 9, 2012 | 07:31 AM
Use a multimeter to check voltage at the pump, check the fuel pump relay, and check the fusable links.
Old Apr 9, 2012 | 01:08 PM
iamericgee's Avatar
what he said^^^^
Old Apr 9, 2012 | 02:37 PM
Check this thread as well
https://www.zdriver.com/forums/showt...ight=fuel+pump
Old Apr 10, 2012 | 02:28 AM
ryn004's Avatar
Where is the fuel pump relay and fuse? I appreciate it f you attached a photo with the location.
Old Apr 10, 2012 | 06:59 AM
Lots of pics in the FSM. Click: www.xenons130.com/reference
The relay is on the right side of the glove box at the a-pillar. There is no "fuel pump fuse". Check the fusable links under the hood.
Old May 23, 2012 | 03:41 AM
ryn004's Avatar
Sorry if I haven't updated this thread, but the garage where my 280zx is parked is not nearby so I can't work on it properly.
I noticed that when the car is ignition is on the fuel pump doesn't but when i disconnect the oil sender unit it does go on.
Anything?
Freshzx
Sep 16, 2014 11:19 PM
RonK
Feb 11, 2013 08:48 PM
Lesnocker
Nov 22, 2010 09:20 AM
kdxzx
Oct 24, 2010 02:54 PM
ern
Oct 20, 2006 07:01 AM
