fuel pressure regulator
Old Apr 22, 2008 | 12:57 PM
dapper189's Avatar
Is there a way to check to see if its working correctly before i put it all back together? I tried searching the previous posts but couldn't find anything that specific.
Old Apr 22, 2008 | 12:58 PM
There's a section in the Haynes manual about it...
Old Apr 22, 2008 | 02:16 PM
dapper189's Avatar
i got the chilton's ill look when i get home
Old Apr 22, 2008 | 02:24 PM
Haynes manual FTW.
Old Apr 22, 2008 | 08:17 PM
lww's Avatar
lww
Head Muckraker
The Chilton's is the worst and contains MANY inaccuracies.
Go here to get a Factory Service Manual:
https://www.zdriver.com/forums/280zx-s130-forums-77/where-do-i-get-factory-service-manual-my-car-15183/
If you can't go that route, find a Haynes. The Haynes and the FSM are very complimentary and should go together whenever possible.
Old Apr 23, 2008 | 12:14 AM
duowing's Avatar
NisTuner
Sorry to threadjack, but I noticed when my car is turned to ON, but not running, like when the fuel pump is priming. I can hear a hiss coming from the pressure regulator area. Would this indicate a leak? Or is this normal?
Old Apr 23, 2008 | 12:23 AM
Have you checked the fuel pressure? Does it leak down?
Old Apr 23, 2008 | 04:21 PM
duowing's Avatar
NisTuner
I haven't checked the fuel pressure in a while. I'll have to check it, the last time I checked it everything was fine. It doesn't smell gassy around it, and I haven't noticed fuel or wetness.
KSpakes87
Feb 26, 2014 03:21 PM
Gingie
Jan 21, 2014 05:40 PM
TeamRonin
Nov 22, 2009 10:02 PM
MistaZ31Turbo
Feb 26, 2009 08:24 PM
SysqoeZ32
Nov 14, 2006 02:15 PM
