running rich (any ideas)
Old Apr 23, 2008 | 05:31 PM
scorpionp54's Avatar
my 82 280zx L28 is running rich right now, just looking for some ideas on what it could be. only 60k miles on engine, original intake system and exhaust.
would appreciate the help.
Old Apr 23, 2008 | 05:33 PM
SEARCHING always helps. Lots of info if you look for it.
Check:
-CHTS
-AFM
-TPS
-Timing
-Spark Plugs
-Cap & rotor
-Vacuum hoses
When and how did it start running rich?
Old Apr 23, 2008 | 05:38 PM
i think itsbeen running rich for a while because my gas milage been not so good during city driving. and itested my o2 sensor and it was reading 800mv at 2500 rpm
Old Apr 23, 2008 | 05:40 PM
^^^ Oh yeah... and check the O2 sensor.
Old Apr 23, 2008 | 05:43 PM
i tested my o2 and its working.
Old Apr 23, 2008 | 09:21 PM
lww's Avatar
lww
Head Muckraker
What about all the other items? Have they been checked yet?
Old Apr 23, 2008 | 11:29 PM
duowing's Avatar
NisTuner
Are you sure the O2 sensor is working? Just because you got a reading from it doesn't mean it's working. If anything the reading should be bouncing around at 2500rpm. A still or consistent reading usually indicates a fouled out or dead O2 sensor. Or an O2 sensor that got rattled around too much, because you left it in the downpipe while you went to stores looking for replacement studs...
A way to check is that little green LED on the bottom of the ECU, once the car is warmed up and at operating temperature you rev the car a few times, then let it sit at idle and see if the LED blinks 5 or more times within a 10 second period.
Z32Fan
Jul 29, 2014 10:00 AM
86300zxNA
Dec 22, 2011 06:04 PM
gnr_70
Nov 15, 2010 07:27 PM
KevinH
24
Aug 1, 2005 10:09 AM
InFaMousZ
May 5, 2004 07:49 AM
