Free 1983 280ZX turbo
Old Dec 21, 2006 | 11:16 PM
Prospector's Avatar
Unhappy Free 1983 280ZX turbo
I have chance to get 280ZX turbo that has been parked last 8 years after friends father died.
Giving me car in exchange for cleaning property to sell.
Tried the car and it starts but dies within 1 or 2 sec after releasing key from the start position.
Also has no power to anything in car except the headlights and key.
No parking lights, interior lights, dash lights, no window power, wipers out, basically nothing works except starter and headlights.
would it be worth getting car to go (35000 miles) and where would I even begin.
Bought repair manual but I'm lost already. Previous cars were always pickup trucks, so this is confusing.
Would both problems be related?
Old Dec 21, 2006 | 11:26 PM
wreckedj30's Avatar
No Club Love
yeah, 3500 mi, is good for a zxt. But i donno about electrical much so your going to have to wait for like nismo or bleach...where is this car at? and is it for sale..lol
Old Dec 21, 2006 | 11:30 PM
tekanitrus's Avatar
check under the hood, there is a long fusebox and inside of it there is a fuseable link.. most likely it's bad.. it runs power to most everything..
just a thought.
Old Dec 22, 2006 | 12:00 AM
BigBirdsZ's Avatar
if the cars been sittin for 8 years u gotta change all the fluids drop the gas tank clean it put new fuel an fuel filter in, an probably some injector cleaner also check the fuses n fusible links so what have u done to the car since u got it? what do u mean go 35,000 miles?
Old Dec 22, 2006 | 12:04 AM
Prospector's Avatar
Would the car be worth getting it to run.
Looking at prices...the free car may not end up being quite so free.
Old Dec 22, 2006 | 12:08 AM
Prospector's Avatar
Spent day charging and recharging battery while testing. Checked all vaccuum lines (ones right off visable), wiring for broken wires, just got manual tonight and looking thru it.
I think I need to stay with pre-emmissions control cars...so much easier
Old Dec 22, 2006 | 12:15 AM
change out the gas... its probably varnish by now. and will screw **** up and will cause the car to not run.. drain it and fill her up with a couple gallons of premium. and change out the fuel filter.. then try to start her again.
Old Dec 22, 2006 | 12:25 AM
emo236's Avatar
confuzed member
your alternator could be VERY rusted as well which would screw up the power to anything. Start to change fluids, filters, etc. heck....even parting it out would yield a lot of relatively free money. heck, depeding on price and my budget at the time, I'd consider taking the drive train for my s30.
Old Dec 22, 2006 | 12:27 AM
i want the drive train. lol. and go stand alone on it. dibs
Old Dec 22, 2006 | 06:28 AM
FubarI33t's Avatar
yeh. If you get it just to part out. ppl on here pay fair money for ZXT part's.
Old Dec 22, 2006 | 07:04 AM
yeah but then if you part it out, one more z body gets crushed, unless it is totally shot, then its time to go
Old Dec 22, 2006 | 07:16 AM
Turbos are overrated.
Old Dec 22, 2006 | 07:43 AM
rogerz's Avatar
Grumpy & Helpful
If it was running when laid up and you think you might like a Z car it would be worth getting it running. They aren't worth a lot of money. If you say it starts and then dies at least you know the engine isn't frozen. Lots of the other stuff sounds like corroded connections or fuses. 35 K on an 83 zxt is just barely broken in. Got one sitting in my garage waiting to be redone. I'm one of the old guys and I like the retro D Jaguar style look. The turbos run away from kids in Honda civics with 6" tail pipes so that is a plus. My guess is if you are a fair wrench you can get her going fairly easy. Do the stuff above about fluids, gas etc. Can you hear the fuel pump start for about 5 seconds when you turn the key to ignitiion. It should which would pressure up the fuel rail. You can pull the hose off the outlet of the fuel filter and run a 4 foot length of hose to a can turn the key and see what comes out. Assume you checked the air intake for mice nests. Need air, fuel and spark to run.
Old Dec 22, 2006 | 10:09 AM
skittle's Avatar
Taste My Rainbow
Where Are The Pics???
Old Dec 22, 2006 | 10:42 AM
emo236's Avatar
confuzed member
just don't pass it up....pass it on to us if you need to!
Old Dec 22, 2006 | 04:48 PM
Prospector's Avatar
Well first day
into it for 300
found the little bearings under some distributor plate were out rolling around under dist cap.
New distributor.........
Somewhere is massive dead short for other power. In fusable link box on passenger side is terminal marked 'B' (battery???), no power there so ran wire from battery and touched it......wire got hot and melted plastic...not good.
went to fusebox on passenger foot hole under dash, hooked hot wire there and same thing...wire got hot and melted plastic.
removed fuse and touched downstream side of fuse plug, got lights to work, radio works, basically everything works when bypassing main buss in fusebox.
Looks like 2 large white wires give power to the upstream side of the fuses, and when putting power to them, my jumper gets hot and melts. They go up into a large bundle of wires to who knows where...can't find the wires in the repair manual. Looks like it's down to cutting tape off the hrness and manually following wires..unless someone knows where they go from fusebox to battery???
When distributor gets in next week then I will be back to starting problem so will work on wires now.
They seem to be 2 seperate problems.
Old Dec 22, 2006 | 06:26 PM
emo236's Avatar
confuzed member
it's not uncommon for fuseboxes to get fried....you might want to locate a new fuse box.
Old Feb 11, 2007 | 10:23 PM
Prospector's Avatar
Well distrib is in....runs fine..on hot shot then nothing.
Just tap the key to start and fires right off.
Will not run on it's own tho.
Things I've checked;
fuel is getting to and is under pressure to the rail,where I disconnected the hose at the pressure regulator (fuel in side) and fuel shot out rather nicely (no pressure guage but was a good stream), so fuel getting to the injectors.
I wouldn't think ALL injectors are bad so have to think that something else is up.
Are there any tests to see if injectors are getting power to tell them to open and allow fuel to pass?
As the ECUs seem to be in the 500 range, I haven't decided yet if the car is worth keeping.
Old Feb 11, 2007 | 10:32 PM
One or more injectors could deffinately be clogged. Pull the spark plugs & look at the tips. That will tell you whas going on.
500.... 500mph range? Hopefully you don't mean $500 range. You can get a turbo ecu for $30-$50 on ebay... $40-$100 from a junk yard that has a guarantee. $500 for the 400hp JWT ecu.
Old Feb 12, 2007 | 07:57 AM
turboboost's Avatar
If you dont want it, Ill take the engine off of your hands
Old Feb 12, 2007 | 08:13 AM
skittle's Avatar
Taste My Rainbow
where are you located again???
Old Feb 12, 2007 | 10:38 AM
Prospector's Avatar
I was thinking about that but never seems to be the exact year and number.
Is there an interchange list somewhere? Maby from another Nissan so I don't pay for the 280Z name?
Other than that I haven't seen new ones for less that $499.
Old Feb 12, 2007 | 11:03 AM
www.car-parts.com
or $249:
http://www.blackdragonauto.com/icatalog/z/0078.html
Frenchie
Jan 11, 2015 10:42 AM
Superduner
Jul 1, 2009 06:27 PM
280zx2by2
Jul 3, 2008 07:36 AM
chrischicoine18
Jan 31, 2007 12:02 PM
rgus30
Nov 24, 2006 08:16 PM
