Figured out starting issue, maybe?
Old Feb 11, 2011 | 10:00 PM
jginther1981's Avatar
okay so tonight my Z fired up.....it is about 20 degrees warmer though. Checked my cold start valve cleaned it up and started the car. Problem is my car is acting lean when i press on the gas until it is warmed up. I hear the fuel pump as usual, but when it is now at operating temperature and idling and 1000rpm...the fuel pump makes a whirring/whining sound.....could this be the issue to my cold start problem....do fuel pumps start going out and not want to start in cold weather?
Old Feb 12, 2011 | 09:33 AM
rogerz's Avatar
Grumpy & Helpful
chts often the cause of weird problems between hot and cold. Vacuum leak another possibility. put a gauge on it. get your fuel pressure at the ring. listening to the pump tells you little.
Old Feb 12, 2011 | 05:13 PM
chts? are you talking about a coolant temperature sensor? i'm not familiar with that acronym rogerz.
Old Feb 12, 2011 | 05:54 PM
CHTS Cylinder Head Temperature Sensor It is located on the passenger side of the head. Check the connector and contacts. Also if you want, you can check the voltage. I don't know what it is though. Mine have always worked.
Old Feb 12, 2011 | 05:55 PM
J-cubZ's Avatar
No hes refering to the head temp sensor on the passenger side of the engine by the number 5 & 6 spark plugs. Is your AFM working? Check your fuel pressure and filter.
Check spark, fuel and air...
Old Feb 12, 2011 | 06:04 PM
got a fresh fuel filter, not sure about the pump though. is the afm the same thing as a mass air flow sensor?
Old Feb 12, 2011 | 06:06 PM
although when i changed the fuel filter....it didn't shoot out, it kinda just ran out by gravity. i expected some pressure. i am trying to located that cylinder head temp sensor, but i can't find it online.
Old Feb 12, 2011 | 07:00 PM
i mean i'm trying to find it for sale. i have a chiltons that shows it on the car. lol
Old Feb 12, 2011 | 07:39 PM
attacksoma's Avatar
http://www.xenons130.com/reference.html
Use this link to Download the work manuals..plus its a good reference site for the 280Zx
1979 280z
Jan 5, 2015 02:58 PM
Unorthodox
Oct 11, 2013 11:15 AM
Lesnocker
Feb 11, 2011 01:13 PM
OpenRange
Aug 26, 2009 12:54 PM
280z racer
Sep 25, 2007 11:29 AM
