F**king Seriously!?
Old 02-26-2011, 04:27 PM
Intrawebz Wizard
BlueKitsune's Avatar
F**king Seriously!?
I've been driving all over today getting things I needed to do done and I finally come home and park my Z and it was fine for about 5 min and I hear a pop and I see coolant on the ground under my car.
The ****ing timing cover blew out. And I don't have the time nor money to fix it. And this pile of crap is my only car left to drive.
I love these Z cars to death but **** stupid **** like this gets on my nerves.
BlueKitsune is offline
Old 02-26-2011, 04:46 PM
ummm.... I think you mean the water pump gasket blew... which is an easy fix. it costs 5 bucks.
snwbrderphat540 is offline
Old 02-26-2011, 04:52 PM
lww
Head Muckraker
lww's Avatar
Unless it's a dead water pump, then it's an easy fix and $25 for a cheap one from Kragen/ORielly.
lww is offline
Old 02-26-2011, 05:26 PM
Intrawebz Wizard
No you can see it pouring out between the block and the timing cover right next to where the lower radiator hose comes in.
Old 02-26-2011, 06:01 PM
Did you use the Felpro gasket or RTV when you installed it?
NismoPick is offline
Old 02-26-2011, 06:11 PM
Intrawebz Wizard
Felpro gasket with some of the gasket prep stuff
Old 02-26-2011, 06:25 PM
Interesting... I would say the gasket wasn't seated properly, because if anything should blow from too much pressure in the coolant system, it SHOULD be the rad cap. What pressure is your rad cap?
Old 02-26-2011, 06:52 PM
Stupid Hurricanes...
260zturbo's Avatar
that sucks to hear hopefully it wont be a big PITA
260zturbo is offline
Old 02-26-2011, 07:07 PM
Intrawebz Wizard
I actually just inspected it very carefully and I found the bolts around that area where barely tight. (Mind you I told the machinist that rebuilt my motor to use a felpro gasket and to use a good gasket glue with it to keep it from doing this!) So thats probably nearly all of the issue. And the cap is stock 13lbs
It already is a big PITA as I'm gonna have to walk 4 or 5 miles to class at 6AM come Monday as I have no money to fix it right now.
Damn and I just put a new oil pan gasket on this engine too. and I sealed that up tight as well so its going to tear it. ****
Old 02-26-2011, 07:23 PM
Part out the TT, you can get a **** ton of money off of that thing and use it to fix/keep up the DD.
hoov100 is offline
Old 02-26-2011, 09:00 PM
Intrawebz Wizard
I'm saving the TT seeing as how the body is straight and clean. But if worse comes to worse I will.
Old 02-26-2011, 09:07 PM
nismo619's Avatar
water pump on the 280zx eazy money ! even a caveman can do it !!! lmao
nismo619 is offline
Old 02-26-2011, 09:15 PM
Primer Grey FTW!
evandubya's Avatar
that sucks tell the mechanic he needs to warranty his work.
evandubya is offline
Old 02-26-2011, 09:26 PM
Intrawebz Wizard
Its not the water pump its the timing cover
I'm gonna ask him Monday what hes going to do about it.
Old 02-27-2011, 02:45 AM
See if you can borrow some money. The timing cover kit was $16 and some change from Napa for me. Anyway, I am sure there is somebody that can help you out. Good luck man.
WildmaN is offline
Old 02-28-2011, 03:54 PM
Intrawebz Wizard
Well I got $100 (TRIED to fix a friends car, damn american ecno-car) So now I'm trying to decide if I should just yank the motor (and leave the trans in if possible) and replace the rear main seal, oil pan gasket, and timing cover gaskets in one go. Or if I should just leave the motor in the car and try not to tear the oil pan gasket taking the timing cover off.
Old 02-28-2011, 04:07 PM
If the oil pan gasket was just recently put on, then you should be able to re-use it. Just remember when replacing the timing cover gasket to copper coat both sides.
hoov100 is offline
Old 02-28-2011, 04:16 PM
Intrawebz Wizard
I did just put it on about... a month ago? but I used a copper coat on it as well thats why I'm thinking no matter what I'm gonna tear it.
Old 02-28-2011, 04:23 PM
If you make sure it's tightened it won't. Especially under coolant.
hoov100 is offline
Old 02-28-2011, 04:42 PM
Intrawebz Wizard
Er... What? I don't think were both talking about the oil pan gasket
Old 02-28-2011, 04:53 PM
this isn't rocket science man, just drop the pan bolts so it is loose and then pull the radiator and then the front cover. you can get this done in a day.
also, there is no way you can pull the motor and leave the trans in there, it will NEVER line back up when going back in... if the rear seal is bad pull it all and just go through any gaskets you have any doubts on and get it all done in one shot.
Old 03-01-2011, 02:46 AM
Believe it or not. I gambled when putting my timing cover back on. My oil pan gasket was actually torn, and such. I just used a lot of blue RTV in hopes that it wouldn't leak. Well sure enough, it is still leak free. So I lucked out. So all in all, I am sure you will be pretty safe, by redoing the timing cover gasket. Just use the blue RTV, it is the best kind. Trust me man. And good luck.
WildmaN is offline
Old 03-01-2011, 06:37 AM
Intrawebz Wizard
Alright Going to napa today to get the parts, I'm getting a new water pump as the one I have has the stamped steel impellers that apparently don't work for ****.
Guess while I'm at it I'll install the dizzy shaft right lol
Old 03-01-2011, 06:07 PM
Intrawebz Wizard
Well got the cover off, the gasket just pealed off the timing cover of course, the machinist didn't freaking seal it at all! And of course, I tore the entire front of the oil pan gasket off. Bleh
One part at a time will be getting here so thats annoying as all hell. I couldnt get the lower rad hose off at all so I had to cut it, If I had more money I'd go get the radiator dipped.
Old 03-01-2011, 10:06 PM
Primer Grey FTW!
evandubya's Avatar
Frustrations abound!!! Sorry man, that's usually how my luck goes too.
Quick Reply: F**king Seriously!?
