Even more issues
Old Dec 21, 2006 | 01:47 PM
skittle's Avatar
Taste My Rainbow
Even more issues
Well i changed out the connectors for the temp thingies on the front of the engine. I went to try to start the beast and guess what NOTHING happened. I checked all of the connections and made sure my battery was charged. I disconnected the starter and when I turn the key it makes noises. Once I re-connect it I turn the key again and nothing happens. Its acting like the battery is dead...
My guess is the alt is bad now...
Am I close?
Old Dec 21, 2006 | 02:01 PM
thxone's Avatar
The alternator should not keep the car from starting or running, if the battery is charged a car will still run, that is one of the things the reserve capacity on the battery is for...with no alt the car should drive for 10-20 minutes on just the battery, after that you are screwed unless you limped the car to an auto parts store. I would look elsewhere for the culprit. Edit: like the solenoid on the starter itself, could be fried.
Old Dec 21, 2006 | 02:10 PM
If you're not getting any power (like the lights / accessories won't turn on) check your battery voltage... and terminal connectors.
Old Dec 21, 2006 | 02:37 PM
skittle's Avatar
Taste My Rainbow
Ok Ok I Get The Dumb *** Award For Today I For Got To Connect To Coil To The Dizzy... Lol But She Is Still Smoking Like An 80 Year Old
Old Dec 21, 2006 | 02:47 PM
thxone's Avatar
Ahhh yes, the coil...good one, lol.
Old Jan 8, 2007 | 02:01 PM
skittle's Avatar
Taste My Rainbow
well i think i might have found out my running rich issue I hope... I got a new fuel pressure regulator and tryed to install it. I found out I need to get new fuel line hoses the ones i had would not come off so I had to cut it.. lol I hope this fixes the issue.
On a side note I'm selling my psp so i can get either a;
1. megasquirt
or
2. a pallnet fuel rail and a better exhaust...
opinions???
Old Jan 8, 2007 | 02:10 PM
is a PSP really worth $300+???
Old Jan 8, 2007 | 02:45 PM
skittle's Avatar
Taste My Rainbow
well not just the psp it has alot of extras and i have more saved up as well...lol
Old Jan 8, 2007 | 02:51 PM
DGriffin's Avatar
1. megasquirt
or
opinions???
Can't you use megasquirt and tune your fuel delivery to get rid of your running rich problem? I dont know that much about Megaquirt but I beleive you can tune it.
Old Jan 8, 2007 | 03:58 PM
skittle's Avatar
Taste My Rainbow
Yeah I Can, It Gets Rid Of The Afm And The Ecu. But At 300+ For The System Its A Lil Much Compared To The 150 For The Fuel Rail
GreenMachine
Aug 10, 2012 07:04 AM
Zfanattic86
14
Jan 14, 2008 11:10 AM
duowing
Sep 21, 2007 07:10 AM
88blanca
Jun 29, 2005 01:34 PM
Ravin
Jun 26, 2005 06:35 PM
