Even more issues
Even more issues
Well i changed out the connectors for the temp thingies on the front of the engine. I went to try to start the beast and guess what NOTHING happened. I checked all of the connections and made sure my battery was charged. I disconnected the starter and when I turn the key it makes noises. Once I re-connect it I turn the key again and nothing happens. Its acting like the battery is dead...
My guess is the alt is bad now...
Am I close?
Am I close?
The alternator should not keep the car from starting or running, if the battery is charged a car will still run, that is one of the things the reserve capacity on the battery is for...with no alt the car should drive for 10-20 minutes on just the battery, after that you are screwed unless you limped the car to an auto parts store. I would look elsewhere for the culprit. Edit: like the solenoid on the starter itself, could be fried.
well i think i might have found out my running rich issue I hope... I got a new fuel pressure regulator and tryed to install it. I found out I need to get new fuel line hoses the ones i had would not come off so I had to cut it.. lol I hope this fixes the issue.
On a side note I'm selling my psp so i can get either a;
1. megasquirt
or
2. a pallnet fuel rail and a better exhaust...
opinions???
1. megasquirt
or
opinions???
1. megasquirt
or
opinions???
1. megasquirt
or
opinions???
