ECU/Computer Codes
Old Jun 28, 2004 | 07:10 AM
icice9's Avatar
Super Siver & Black Stud
your problem sounds like your ignition modual.. its located on the side of your distributer.. it a lil black plastic box....when they go bad your car will just die for no reason... i changed mine a few years back..
Old Jun 28, 2004 | 09:29 AM
I was thinking along the same lines. Either that ignitio module or your coil. Might as well replace both. Get a used ignition module, and a new coil.
Old Jun 28, 2004 | 11:28 AM
icice9's Avatar
you dont want to put a used one on.. its going to do the same thing sooner or later.. a new one is gonna cost you around the lines of $100 to $120
Old Jun 28, 2004 | 05:07 PM
Z*Tech's Avatar
sudden death
One of two things, Ignition module or fuel pump.
Either will cost you dearly, the last fuel pump I purchased was $225.00 and the Ignition module was $235.00.
If the pum won't have fuel pump is going out you won't have pressure when it stalls (loosen the fuel line CAREFULLY)
If its the Ignition module you won't have spark.
Don't waste your time replacing the coil unless its leaking oil, I have only seen two faulty coils in the last thirty years.
Seattle_Max
Mar 26, 2014 04:47 PM
Aphrodite
Jun 11, 2009 11:50 PM
MaxQ
Jun 22, 2005 04:05 PM
duckyz
Oct 27, 2003 06:57 PM
modified300zxt
Oct 16, 2002 10:15 AM
