distributor conversion
Old Oct 18, 2006 | 06:33 AM
VernonZ's Avatar
I am going to rebuild a 81 turbo motor, and I have been reading that
the CAS on the 81 is not very good and that a swap to the 82/83 turbo
distributor setup is better. I want to do this but have no idea how to perform the swap. Has anyone done this and if so could you tell me how?
thanks,
VernonZ
Old Oct 18, 2006 | 07:10 AM
Just need the 82-83 distrib & the oil pump/distrib drive shaft. I believe the harness plug is the same for both.
-One thing I'm not sure about, is if the 82-83 ecu is needed... The 81 cas might send a diff signal than the 82-83.
Old Oct 18, 2006 | 07:13 AM
VernonZ's Avatar
Thanks NismoPick
Old Oct 18, 2006 | 11:35 AM
FubarI33t's Avatar
I know that on a 81, the ING Control box mounted on the side is Diff then the 83. 81 has the one 2 wire plug on top. 83 has on top, and on side
Old Oct 18, 2006 | 11:52 AM
We're talking about the turbo model... the ignition module for the turbo is located on the coil bracket, not distrib.
Old Oct 18, 2006 | 12:03 PM
FubarI33t's Avatar
i was just stateing it.
Old Oct 18, 2006 | 02:53 PM
wreckedj30's Avatar
No Club Love
What up black, and where you been. Did you ever find a turbo motor?
Old Oct 18, 2006 | 04:37 PM
jfairladyz's Avatar
The 81's CAS is probably more accurate then the later in-the-dizzy setup (if it's setup properly). Having the CAS in the dizzy means whatever play there is in the dizzy and its drive gear is going to transfer to the CAS.
Old Oct 18, 2006 | 05:20 PM
nismo619's Avatar
just get the dissy from a 82 or 83 turbo .. u will need all the parts thou ! dissy pump shaft .. i think the oil pump is still the same on the 81 -82 - 83 280z turbos i had a 81 280zxt with a p-90a engine running the stock 83 dissy.. worked fine with teh stock 81 turbo ecu.. no problem !
Old Oct 18, 2006 | 06:59 PM
wreckedj30's Avatar
No Club Love
Yo black just read the turbo swap, very nice.
cpark_12
Feb 12, 2013 06:21 PM
BackHouseZ
Feb 9, 2011 09:30 PM
Zcarlover
Nov 3, 2008 09:29 PM
ArizonaZ
Feb 6, 2008 08:13 PM
ChEng
Jan 8, 2006 10:36 PM
