Damn my luck
Old Sep 26, 2006 | 09:58 AM
skittle's Avatar
Taste My Rainbow
Damn my luck
well i thought all was going good untill now. I started my car this morning to move it. it started fine, moved the car and shut it off. Tried restarting it to
move it agian for some door MX and now it won't start!!!!
Old Sep 26, 2006 | 10:10 AM
Fuel pump prob?
Old Sep 26, 2006 | 10:37 AM
skittle's Avatar
Taste My Rainbow
yeah thats my guess when i put the key on its supposed to turn on. I think I lost power to it.
Old Sep 26, 2006 | 10:42 AM
prolly the relay
Old Sep 26, 2006 | 11:06 AM
skittle's Avatar
Taste My Rainbow
ok its not the fuseable links got power to each injector. next is to try the relay. crossing fingers..
Old Sep 26, 2006 | 11:07 AM
skittle's Avatar
Taste My Rainbow
next question where is the relay?? i can't seem to find it in my haynes manual
Old Sep 26, 2006 | 11:17 AM
Fuel pump relay is between the dash and a-pillar on the passenger side. You prolly need to unbolt the dash wiring block to get to it.
Before you do that, have you checked for voltage going to the fuel pump?
Old Sep 26, 2006 | 11:27 AM
skittle's Avatar
Taste My Rainbow
no no voltmeter i think one of my coworkers has one though...
Old Sep 26, 2006 | 11:28 AM
skittle's Avatar
Taste My Rainbow
this is going to be a b!tch....
Old Sep 26, 2006 | 11:43 AM
You can use a 12v light bulb if no voltmeter.
Old Sep 26, 2006 | 12:55 PM
lww's Avatar
lww
Head Muckraker
$13.99 at Home Depot
http://tinyurl.com/ehanf
Old Sep 26, 2006 | 01:23 PM
skittle's Avatar
Taste My Rainbow
i hooked up a temp light
Old Sep 26, 2006 | 01:52 PM
I think one of the relays are behind the battery. There is a plastic plate there you can remove.
The other one is behind the dash passenger side. Remove the glovebox to get at it. It is right along the right wall of the car. There are a couple relays there. One is for fuel
Old Sep 26, 2006 | 02:01 PM
skittle's Avatar
Taste My Rainbow
i hope that fixes the issue... I finally get it running well and this happens..
Old Sep 26, 2006 | 02:43 PM
lww's Avatar
lww
Head Muckraker
Welcome to the world of 25 year old cars... It's almost ALWAYS related to the electrical in some way. A sensor wire, a relay or a bad/corroded connection.
Old Sep 26, 2006 | 02:46 PM
skittle's Avatar
Taste My Rainbow
OK JUST FOR THE HELL OF IT, I TRIED TO START IT AGAIN. IT STARTED!!!! AND ALL I DID WAS WAIT A LIL WHILE.. IT ACTED LIKE IT WAS FLOODED BUT IO KNOW THATS NOT THE ISSUE. nOW WHEN I WAS ON MY WAY TO WORK THE CAR VIBRATES LIKE IT HAS A REAR TIRE BLOWN OUT. YOU KNOW WHAT I MEAN THE THUMPING KIND OF VIBRATION... I'M STUMMPED ON THAT ONE AS WELL.
Old Sep 26, 2006 | 08:36 PM
FubarI33t's Avatar
i know one problem you mihgt have. besides maby a brokin rear end mount. I think your cap's buttion eather broke, or it got stuck down.
myfirstz31
Mar 14, 2006 07:50 PM
VegasEdge
Nov 21, 2005 02:15 AM
RodMoyes
Jun 14, 2005 03:11 PM
b300z
Oct 29, 2004 12:53 PM
b300z
Oct 8, 2004 04:13 PM
