CHTS compatibility?
Old Aug 16, 2006 | 05:54 PM
duowing's Avatar
NisTuner
CHTS compatibility?
Is the CHTS for the non-turbo compatible with the Turbo? Also how much room for error does the CHTS allow for in OHMing it?
Old Aug 16, 2006 | 07:42 PM
I've swapped turbo & na head temp sensors before.... they worked the same.
Old Aug 17, 2006 | 08:03 AM
duowing's Avatar
NisTuner
Cool, thanks for the info. I'm gonna swap around the CHTS sensors from my N/A to Turbo and see if that makes any difference.
Old Aug 17, 2006 | 09:52 AM
oh good. I did the same because my NA had a fairly new one, but it made no difference. My car still runs like crap. I'm getting very frustrated with this junk engine...
Old Aug 17, 2006 | 09:58 AM
junk "electronics" not "engine"
Old Aug 17, 2006 | 10:03 AM
so true... stupid 25 yr old electronics. I almost think the wiring harness could be bad. That's my last thing to change out.
Maybe if I do the Z31 ECU swap, I'll just swap in the Z31 wiring harness too. I think that is one method of the swap, correct?
Old Aug 17, 2006 | 10:07 AM
Quite a bit more work, but yes, fresher/updated wires.
Old Aug 17, 2006 | 11:37 AM
duowing's Avatar
NisTuner
Ok, so I OHMed my Turbo Z and I was getting a reading of 1.9 from the CHTS. The garage door had been open for a few hours, but it felt slightly warmer in the garage and I was getting a reading of 2.1 OHMs. I'm thinking maybe the CHTS is just off by a little on the turbo. It's really hard to figure out. I was thinking I should get an A/F gauge like Nismopick has said, but then it occured to me that if the O2 sensor doesn't work until a certain temperature that the A/F gauge would be of no use to me because generally by the time the O2 would be working the car's running fine.
Old Aug 17, 2006 | 04:06 PM
lww's Avatar
lww
Head Muckraker
At that point, I would actually consider making an entirely new harness. The only problem would be finding the right color coded wires or you would have to make a detailed crib sheet for the new colors.
With some time and a little elbow grease, you could do it. If you're careful, you could re-use the connectors as well.
How much time do you have...?
Old Aug 17, 2006 | 05:33 PM
RodMoyes's Avatar
Doesn't post much...
Sorry to hear you're still having issues with the motor Bleach, I know how hard you've been working on it. I hope you get it figured out soon... or stumble across an unexpected chunk of change that will afford you the ability to scrap all that 1980's crap in favor of a full tilt MegaSquirt wideband set up
Rod
Old Aug 21, 2006 | 03:30 PM
duowing's Avatar
NisTuner
How much coolant would need to be drained to pull out my CHTS or should I just drain it all?
Old Aug 21, 2006 | 04:47 PM
You don't drain any... it's not a coolant temp sensor, it's a HEAD temp sensor. It's not in a coolant passage.
Old Aug 21, 2006 | 05:00 PM
duowing's Avatar
NisTuner
Yeah I found this out after I drained the coolant from my 2+2. Another thing that goes to show this Haynes guide isn't exactly accurate. It's too bad they didn't wait until 1983. In the Haynes guide they give info to remove Water/Cylinder Head Temp Sensors. It says you need to drain coolant. I noticed the CHTS that came from my 2+2 was not wet at all, and I didn't have containers so I could drain the coolant and reuse it from my Turbo Z. So I started undoing the Turbo Z's CHTS to find no coolant came out. Then I realized Haynes was again not to helpful when it comes to the 82-83 Zs.
Old Aug 21, 2006 | 11:14 PM
loosenut's Avatar
sorry to thread hijack here, but is your maf ok(dirty?)? what is your engine doing exactly?
Old Aug 22, 2006 | 07:00 AM
He had clogged injectors, but thas fixed now.
Old Aug 22, 2006 | 09:31 AM
boost leak at the base of the injectors. I changed to a different style of injector holder. All fixed.
I changed the fuel pump in my car without draining the tank. The main fuel feed line poured out fuel for that brief moment when I moved it from one pump to the next.
Old Aug 22, 2006 | 09:34 AM
Ah yes... I had that happen too. The next time I did that, I clamped on some vice grips so I didn't get hella sprayed.
Old Aug 22, 2006 | 09:37 AM
I just held my mouth under the line so I wouldn't get the extra fuel on the garage floor. It was only about 1/4 cup of gas.
eZdoesit
Oct 22, 2011 04:54 PM
atmel101
Aug 25, 2010 06:18 AM
91Zman
Apr 5, 2006 03:06 AM
highwaystar
Dec 15, 2004 09:05 AM
newb81280zx
Oct 19, 2004 09:27 AM
