Cams, Pistons, Injectors and everything else.
Old Apr 2, 2012 | 08:41 PM
  #26
Out of balance?
It's common practice to line bore or hone the caps and block and use oversized bearings. I'd go to a different machine shop.
http://elmersengines.com/pages/Machine_Shop_Service
Old Apr 2, 2012 | 09:48 PM
  #27
WanganDevilZ's Avatar
The Emblem Thief y0!
Out of balance?
The connecting rods boyo, the main caps are smooth and will accept their old crankshaft friend nicely.
I guess I could just get new rods, but, I'd rather use these, as they seem okay, that lip just needs to be fixed... I damn myself for throwing away the scratched pistons, as only the piston was broke'd, not the rod.
Old Apr 2, 2012 | 09:52 PM
  #28
woops... reeden 2 fazt.
They can still bore the rods and balance once attached to the pistons. I had that done on my first engine build (plus magnafluxed the rods).
Old Apr 9, 2012 | 04:40 PM
  #29
The stock L28ET cam is far from limiting.
I have two L28ET cams, right now, neither of them are exactly... "Worthy" of placing back into a brand new motor, new valvetrain etc.
Which cam would be best, or say like, a stage I upgrade..? I'll probably stick with the stock turbo for a little bit, but eventually get into a Holset HX35
So, which cam is suggested?
Old Apr 9, 2012 | 11:01 PM
  #30
Are the lobes worn? Scratched?
Whenever I build a motor, modified or stock, I make sure it runs right before I dive into the odds and ends of "modified parts". It's a whole lot easier diagnosing problems when everything is stock, rather than tons of aftermarket / performance parts that make you guess what's wrong. I suggest using the stock turbo cam unless the lobes are damaged, get the motor running correctly, and then change out the cam if you want (I have a write-up in the Gen-Tech on how to change the cam with motor in car). Just "IMHO"
Old Apr 10, 2012 | 05:41 PM
  #31
I'll double check any damage on the cams, they just look like crap, when I take the pistons in to get them attached to the conrods I'll have them see if they be messed up
Old Apr 20, 2012 | 02:59 AM
  #32
joel280zt's Avatar
Not to rehash the past, but we've discussed the "L28ET vs VG30ET" before:
L motor build questions - ZDriver.com
I don't get why people keep talking about the VG30ET over the L28ET... it's a pointless swap into an S30 / S130 unless you are doing it just to say you did it.
Blah blah blah... I won't argue a brick wall.
I was grave digging this thread, and found this on another forum.
VG: Better combustion chamber design, less prone to detonation (but not the best, by far), better response to mods, a bit harder to work on, uses timing belt.
L: Timing chain, sounds cooler, bolt on mods are more available.
I thought it was funny.
Old Apr 20, 2012 | 02:18 PM
  #33
To those of you who aren't friends with me on facebook, I got my pistons attached to the refurbished connecting rods I got a hold of last week.
Got paid today, money in the bank, soon, main bearings!
Also, does the main seal kit from MSA have the side seals for the rear?
90z32
Aug 15, 2011 04:06 PM
GraveDigger
Nov 8, 2008 03:01 AM
90NA300ZX
Jun 23, 2005 08:03 PM
duckyz
Feb 23, 2004 07:26 PM
quansta
Apr 13, 2003 11:13 AM
