Before I Order
Old Feb 28, 2010 | 11:29 AM
FubarI33t's Avatar
Before I Order
This is for a Triple Weber 40mm Carb set up
In Basket: All prices are SummitRacing
ARP 202-4206 price 139$
Mallory HyFire 6 6855M 199$ with rev limiter, .6amp per 1K rpm draw, 520V out to coil
Mallory ProMaster e coil - Included with Ign Box-135Milijoules
Mallory Power Filter 29351 37$ For Unilite Dizzy
A few small things like Ign Box rubber mounts, and ARP Lube.
On Bid:
Weber 40MM Triple Matched set, with Mik Short intake & K&N Filters for all three carbs, Bid at 504$
Looking For:
P90 Non Hydro Complete can be missing cam
Settle for N42 Complete can be missing cam
Parts already owned:
Mallory Unilite full elect Dizzy for L-series Motor 37 series
3 Core Alum Radiator
Comp Cams Cam- 268 Dur 435 lift
And a few "Cosmetic:things, like MSA's Adjustable Alt Bracket, Luckly i found these at
another site for half of MSA's price
:d:
I will use the stock bottom end 83 F54 with flat tops since it's low mileage, So the Comp will be up a lil with the P90 i hope to get in the 9's(comp) Also i plane to use the stock EFI pump with a decent FPR and use the factory return line.
If any part of this set up will not work, please tell me, or if a price listed is cheaper and you know where please tell me
it is 1017pm on the 28th, two days i am ordering these parts unless told otherwise.
Not pertaing to engine, but i also just got the MSA 6 piece SS break line kit, both there Weber carb books, and two of there "Z" logo fender covers(had my eye on a set of them for awhile) I sticking with factory breaks, just refresh them with new lines, fluids, pads, rotors and caliper rebuild(all 4) Once my tires get wore out, there still brand new, i will get new rims and tires. and lower it at the same time
280zForce
May 9, 2012 06:59 AM
wgc_3
Nov 28, 2006 07:10 AM
SinCity350Z
May 8, 2006 02:05 PM
Steves1979280zx
Feb 12, 2006 09:42 AM
SinCity350Z
Feb 2, 2006 05:44 PM
