Before I Order
This is for a Triple Weber 40mm Carb set up
In Basket: All prices are SummitRacing ARP 202-4206 price 139$ Mallory HyFire 6 6855M 199$ with rev limiter, .6amp per 1K rpm draw, 520V out to coil Mallory ProMaster e coil - Included with Ign Box-135Milijoules Mallory Power Filter 29351 37$ For Unilite Dizzy A few small things like Ign Box rubber mounts, and ARP Lube. On Bid: Weber 40MM Triple Matched set, with Mik Short intake & K&N Filters for all three carbs, Bid at 504$ Looking For: P90 Non Hydro Complete can be missing cam Settle for N42 Complete can be missing cam Parts already owned: Mallory Unilite full elect Dizzy for L-series Motor 37 series 3 Core Alum Radiator Comp Cams Cam- 268 Dur 435 lift And a few "Cosmetic:things, like MSA's Adjustable Alt Bracket, Luckly i found these at another site for half of MSA's price :d: I will use the stock bottom end 83 F54 with flat tops since it's low mileage, So the Comp will be up a lil with the P90 i hope to get in the 9's(comp) Also i plane to use the stock EFI pump with a decent FPR and use the factory return line. If any part of this set up will not work, please tell me, or if a price listed is cheaper and you know where please tell me it is 1017pm on the 28th, two days i am ordering these parts unless told otherwise. Not pertaing to engine, but i also just got the MSA 6 piece SS break line kit, both there Weber carb books, and two of there "Z" logo fender covers(had my eye on a set of them for awhile) I sticking with factory breaks, just refresh them with new lines, fluids, pads, rotors and caliper rebuild(all 4) Once my tires get wore out, there still brand new, i will get new rims and tires. and lower it at the same time |
