anyone ever have this clutch problem?
Old Aug 21, 2006 | 12:44 PM
Steven280ZX's Avatar
well wen i pressed the clutch pedal down it went all the way down then stuck there... like it didnt come back up it will still shift though. anyone one know what may be the problem? my dad thinks i gotta rebuild the clutch but i dont wanna do anything unnessesary. thanks
Old Aug 21, 2006 | 01:12 PM
more info!
this car has never been driven by you, correct? So it still goes through the gears while the engine is off and the pedal is stuck at the floor?
I think you just have no fluid in your clutch hydralic system.
Old Aug 21, 2006 | 01:34 PM
lol thanks bleach man everytime u post u make me look like an idiot thanks for all the help
Old Aug 21, 2006 | 02:39 PM
no fluid hopefully...otherwise slave cylinder coulda went out...happened to me in the middle of crazy traffic.
Old Aug 21, 2006 | 03:23 PM
skittle's Avatar
Taste My Rainbow
yeah the fluid is what your problem most likely is. I just had to bleed my system after my engine swap. Its a PTA if you do it by yourself. If you have no one to help you the best way to bleed it is connect a hose to the fitting on the bottom right side of the tranny. then put the other end into a jar filled with fluid. that way when you pump the the pedal the air goes into the jarand not back into the line. Just make sure your reservior is kept filled or you will suck air back into the system... NOT FUN. eaiser just to get some one else to help ya.
Old Aug 24, 2006 | 09:26 PM
you can also gravity bleed the system once you pump it up, then bleed, then pump and gravity bleed some more.
Old Aug 24, 2006 | 09:43 PM
skittle's Avatar
Taste My Rainbow
now thats alot harder... at autozone they have a 1 person vaccuum system for around $30. Not sure if they are good or not. I'm taking mine to a place that can power bleed
Old Aug 24, 2006 | 10:39 PM
My "one person bleeding system" is called a 2x4. Just wedge a 2x4 between the pedal & seat, then roll back & open the bleeder valve... wala!
Old Aug 24, 2006 | 10:43 PM
jfairladyz's Avatar
The best means of doing it is to use a vacuum source at the master cylinder and pulling in fluid through the bleeder and sucking the air out through the master cylinder. This ensures there is no air trapped in the system.
Old Aug 24, 2006 | 11:22 PM
skittle's Avatar
Taste My Rainbow
yeah if you can find one that is
Yardjass
Apr 8, 2012 07:58 AM
snwbrderphat540
28
Apr 29, 2008 11:43 AM
anyrug
Mar 11, 2007 08:05 PM
Fourtunata
Jul 30, 2006 04:31 PM
MarkieMark
Sep 13, 2005 05:25 PM
