Another brake question
Old Dec 10, 2012 | 09:19 AM
corbith's Avatar
I'm hoping someone here can help me out. I am working on the brake system and was looking at the master cylinder, see attached pictures. Mine does not look like those from the FSM or Haynes manuals. One of the filler holes has a molded cover that does not appear to be removable. Any ideas of why this is different as I thought this portion was for the rear brakes. Do I need to pry this off and fill or do I just fill both through the main opening?
Attached Thumbnails Another brake question-brake1.jpg   Another brake question-brake2.jpg
Old Dec 10, 2012 | 09:48 AM
Looks like a normal 82-83 brake master to me...
The 79-81 master had the two reservoirs. Just about every car these days has one reservoir for the entire brake system (front and rear).
Old Dec 10, 2012 | 10:05 AM
corbith's Avatar
Thanks for confirming Nismo, that is what I was thinking but both manuals show two reservoirs. Just wanted to make sure I wasn't missing something as I learn more about this car.
Old Dec 10, 2012 | 10:07 AM
Are you using an 82-83 FSM? I know there's a section covering the different brake masters (I'm at work otherwise I'd tell you the page).
Old Dec 10, 2012 | 10:29 AM
corbith's Avatar
I downloaded the manual for an 82, folder containing all the PDF's is called "82_datsun_280zx". In the brake section (BR.pdf) it has diagrams for NABCO and TOKICO makes but they both sjhow two reservoir caps, it's the internals that appear to be different.
Tree_Stump
Dec 30, 2015 08:16 PM
Wolfsnack
Jul 12, 2014 08:04 PM
Murph Z32
18
Feb 9, 2008 04:11 PM
smokey
Feb 25, 2007 02:17 AM
s/cL3.0
16
May 2, 2005 08:52 PM
