'83 Turbo Digital Speedo inop
Old Aug 13, 2020 | 04:25 PM
JeremiahMckenna's Avatar
I got in the car, started it up and the digital gauges are not working. This includes the Speedometer, Tach, Fuel and Temp. All of the other lights on the top (brake/door/etc) work, as well as the small square one that tells you if your water and radiator are fine or not, work. All of the analog gauges in the middle of the venter stack work fine also. The headlights/turn signals also work fine.
I did tow it from Arizona to Louisiana on a 4 wheel car carrier a few weeks ago, and all was working fine before and at the time I drove it onto the trailer. I also found the turn signal blinker switch on the floor board, and plugged that back in, and all of the turn signals work just fine. I tried to see if one of the wires that controlled the digital parts of the display had also come loose, but I was not able to see a heck of a lot from under the dash, on the floor board. So I then tried to remove the entire cluster, but it would not come out completely, or far enough for me to see anything behind it. So I figured I would stop and ask if maybe there is something easy I am missing before I try to take the dash cluster out the rest of the way.
Yes, I checked he fuses, and all are fine.
Thanks,
Jeremiah
Monkies
Aug 5, 2012 10:05 AM
TXexit49
Nov 27, 2009 11:57 PM
BackHouseZ
Jul 12, 2008 04:47 PM
agrias120
Aug 28, 2003 06:59 PM
Grendel
Apr 8, 2002 06:58 PM
