82 ZX feels weird after smog
Old Feb 8, 2011 | 05:08 PM
XedLos's Avatar
I took my car to get smoged and after I got it bak it feels weird. It feels like it's shakes a lot. If I let it idle I feel like it will die. It doesn't die but idles around 700rpm.
Ant ideas of what's wrong
Old Feb 8, 2011 | 05:20 PM
did you plug the injector back in?
Old Feb 8, 2011 | 05:41 PM
Timing?
Old Feb 8, 2011 | 05:52 PM
XedLos's Avatar
I haven't touched it since smog. What should I check. How can I adjust the timing?
Old Feb 8, 2011 | 10:05 PM
I imagine they just turned down the timing to get it to pass.
You can download the FSM here: www.xenons130.com/reference
Click: https://www.zdriver.com/forums/240z-260z-280z-performance-technical-124/timing-31560/
Timing directions:
-Hook up timing gun
-Loosen dizzy tangs (10mm)
-Disconnect vacuum advance line
-Start motor
-Point timing gun at crank timing marks
-Rotate dizzy to desired advance
-Shut off motor
-Tighten dizzy
-Drive happy
On a stock 280zx non turbo, the timing is set to 8*.
Old Feb 10, 2011 | 08:39 AM
XedLos's Avatar
I have a non turbo. Is there any way to do it without a timing light?
Old Feb 10, 2011 | 09:02 AM
You can... but you'll never get it set dead on.
Just rotate the dizzy clockwise or counterclockwise until it runs better. Or, just borrow a neighbor's timing gun, or drive on down to your local parts shop as they should have one you can rent or borrow in the parking lot. =)
A timing light would also be a good investment for you, since you can get a basic one for about $15-$20.
Jennings.brent6
May 30, 2014 11:10 PM
LikeZcars
Dec 9, 2011 11:10 PM
bardabe
Oct 2, 2010 03:49 AM
duowing
Jul 12, 2008 09:19 AM
mbonanni1856
350Z Performance / Technical
Jan 17, 2008 02:37 PM
