82 ZX feels weird after smog
I took my car to get smoged and after I got it bak it feels weird. It feels like it's shakes a lot. If I let it idle I feel like it will die. It doesn't die but idles around 700rpm.
Ant ideas of what's wrong |
did you plug the injector back in? :biggrin:
Timing?
I haven't touched it since smog. What should I check. How can I adjust the timing?
I imagine they just turned down the timing to get it to pass.
You can download the FSM here: www.xenons130.com/reference Click: https://www.zdriver.com/forums/240z-260z-280z-performance-technical-124/timing-31560/ Timing directions:
(Post 287449)
-Hook up timing gun
-Loosen dizzy tangs (10mm) -Disconnect vacuum advance line -Start motor -Point timing gun at crank timing marks -Rotate dizzy to desired advance -Shut off motor -Tighten dizzy -Drive happy |
(Post 290833)
On a stock 280zx non turbo, the timing is set to 8*. |
You can... but you'll never get it set dead on.
Just rotate the dizzy clockwise or counterclockwise until it runs better. Or, just borrow a neighbor's timing gun, or drive on down to your local parts shop as they should have one you can rent or borrow in the parking lot. =) A timing light would also be a good investment for you, since you can get a basic one for about $15-$20. |
