82 280zx: Idle Problem
Old 08-13-2013, 08:50 PM
Crusty_Lips's Avatar
Hey guys, I am a noob FYI... I have a problem with my Z. It Idles rough and misfires a lot. It idles like its on a urge of stalling. When I give it gas it revs like **** then dies. I replaced the spark plugs and wires and its still the same. I have a feeling its my fuel pump. I did hear a lot whining noises and and humming noises all the time prior to this situation. Can a bad fuel pump cause my car to idle and act up like this? Couple days before all of this I did notice loss of power and the car felt different. I was scared that I had some weak cylinders but when I tested them all cylinders had good compression, so Im guessing it should be an air or fuel problem. Any info will help.. Please and Thanks
Crusty_Lips is offline
Old 08-14-2013, 07:20 AM
The fuel pump is external inline, so it will always be louder than an in-tank pump like on most cars these days. But if you suspect the fuel pump, check the fuel pressure.
Also check:
TPS
CHTS
AFM
and timing
NismoPick is offline
fanglord
06-08-2014 09:02 PM
Z Pal
02-27-2014 08:50 PM
motormark
06-20-2012 06:10 PM
nismodrifterx
08-19-2011 03:37 PM
deckart
11-27-2002 04:20 AM
Quick Reply: 82 280zx: Idle Problem
