Idle Problem
Old Jan 20, 2014 | 10:21 AM
Z Pal's Avatar
Idle Problem
My 1985 non-turbo 300zx has an idle problem which has been going on for some time and seems to be getting worse. It idle's rough at idle, runs fine at higher RPM's. I changed the plugs and wires and put in NGK plugs, gapped to specs. The battery is one year old and has clean corrosion free connections. I replaced the starter 10 months ago. I cleaned the TPS and connectors with electronic cleaner and that seemed to make a big difference but gradually the idle problem came back. I took the hoses off the MAF and looked in there, it seemed to be pristine so I didn't do anything to it. I cleaned the ECU connectors with electronic cleaner. I took it to a garage where the mechanic hooked it up to a diagnostic analyzer and said the number 6 cylinder was misfiring. He checked the no. 6 fuel injector and said it was good. The compression was 170 lbs. across all cylinders. It ran good for a little while after he changed the cap and rotor but then the idle problem returned. Now, an idle problem like this happened years ago, I took it to the Nissan dealership and they changed the distributor. That cured the problem. I'm wondering what you guys think. Should I go ahead and change the distributor or should I look somewhere else?
Old Jan 21, 2014 | 08:29 AM
86tcoupe's Avatar
when ever I had a rough idle but runs ok full throttle
I start with a leak down or a cold ( completely ,has not been run in 12 hours like ) compressin test
the 170 psi sounds as it was done hot which distorts the readings.
it can save a lot of $$ needless electric repairs.
You might have a hyrdo lifter parcially clogged not able to bleed at low RPM
inexpensive to replace if you do it
Old Jan 21, 2014 | 11:53 AM
Z Pal's Avatar
Thanks for the tip, I'll have to buy a leak down tester and do the test.
Old Jan 22, 2014 | 08:25 PM
86tcoupe's Avatar
A good quality compression guage works as well or better leakdown testors are $$$ and take a bit of training to get down
Old Jan 22, 2014 | 09:36 PM
Z Pal's Avatar
I know, I just bought a leak down tester at Napa for $130. It has 2 gauges: one PSI readings 0-100, the other a percentage of pressure loss gauge. I have an air compressor so I should be good to go.
Old Feb 2, 2014 | 01:55 PM
ch33z3x's Avatar
Have you checked fuel pressure/ changed the fuel filter?
Old Feb 2, 2014 | 02:18 PM
Z Pal's Avatar
No, that's another gauge I have to buy. The fuel filter was changed last year. I'm waiting for good weather to do the leak down test.
Old Feb 3, 2014 | 05:39 PM
86tcoupe's Avatar
you can likely get your $130 back testing other cars for people . it is $$$ to have done in a shop
Old Feb 27, 2014 | 08:50 PM
Z Pal's Avatar
Idle problem solved
I decided to follow the FSM procedures for error codes. I was getting an error code of 23 (throttle valve switch(idle switch) circuit). I then followed the Electronic Control System Inspection (EF & EC-62) for the throttle valve switch. I checked the signal for the ECU. It was ok so I replaced the ECU as directed. Problem solved, the rough idle, stalling, hesitation, stumbling problem disappeared immediately when I started it up. I replaced the ECU with a re-manufactured unit from Cardone (72-3033). They sell 8 models so it's important to get the right one. The car originally came with California emissions because it was sold in California but I'm in Montana so I opted for the Excl. Calif. emissions computer. I bought it from Car Part Kings on Amazon for $272.28 + $7.50 shipping. The core exchange is $70.
https://www.cardone.com/find-parts/v...00ZX&year=1985
fanglord
Jun 8, 2014 09:02 PM
nismodrifterx
Aug 19, 2011 03:37 PM
jooom
Aug 6, 2005 04:35 PM
mm107
Aug 3, 2005 06:43 PM
deckart
Nov 27, 2002 04:20 AM
