280zxt idles when cold wont idle when warmed up ??
Old Dec 23, 2012 | 08:29 AM
81turbocoupetx's Avatar
I have a 81zxt that idles fine when cold and when warmed up and driven keeps dying at idle..Anybody else ever have this issue/remedy?
Thanks in advance !
Old Dec 23, 2012 | 01:48 PM
When was the last time it got any kind of tune up?
Old Dec 23, 2012 | 02:17 PM
rogerz's Avatar
Grumpy & Helpful
check your fuel pressure. check the chts. check for vacuum leaks.
Old Dec 23, 2012 | 04:44 PM
Has a fairly recent plugs , wires and dist cap Nismo.. was idling fine even after warmed up til recently.. fuel pressure is about 50 Roger.. chts?? Will continue to look for a vac leak ! THANKS !! Has EGR valve got anything to do with idle?
Old Dec 23, 2012 | 06:30 PM
ThaPimpShrimp's Avatar
To my knowledge EGR should not affect it.
I agree to check the CHTS, if you don't know what that is look up the FSM and find it in there (Cylinder Head Temperature Sensor - should be on the passenger side of the block under the 5th and 6th spark plug I think).
Does the car not start again until it's cooled down? A bad Ignition Control Module can cause issues that are similar.
Old Dec 23, 2012 | 09:53 PM
rogerz's Avatar
Grumpy & Helpful
if the diaphragm is blown on the egr it will affect the engine. loosen the two bolts and slip a piece of tin can in there then tighten things down.
Old Dec 23, 2012 | 11:41 PM
Also now that I am rethinking this you want to be checking all of the major sensors (AFM etc). More info would be really great.
Are you saying it won't run at all once it warms up, or it just won't idle. How does it drive once warm if it does drive?
Old Dec 24, 2012 | 10:38 AM
It just wont idle after warmed up and you drive around the block. It will restart but when stoping to turn a corner or just stopping when back at garage it will die..
Old Dec 24, 2012 | 10:48 AM
Thanks !
Thanks again Guys Merry Xmas !
Old Dec 24, 2012 | 11:15 AM
Wonder if the air regulator on top of the motor could be failing after warm up? Not sure of what all it does when..
Old Dec 24, 2012 | 01:17 PM
Air regulator, AFM, CHTS, and/or ignitor as everyone has previously mentioned. Also the AAC valve (aids the turbo model idle).
Check them... do it... do it...
If you haven't done so yet, I highly suggest downloading the FSM for free from www.xenons130.com/reference
Old Dec 25, 2012 | 04:15 PM
One of the best things you can do right now. Is pull the connectors, and with a toothbrush and WD-40 clean all the connectors, let them air dry and put them back on. And see if that helps if not. then just use process of elimination. It is fun trust me, been there done that. lol But do what Nismo said, and download the FSM. Quite handy in a pinch, good luck.
Old Dec 25, 2012 | 08:51 PM
If you haven't done so yet, I highly suggest downloading the FSM for free from XenonS130 - S130 Reference
Was the "do it... do it...." in an Arnold Schwarzenegger accent?
Old Dec 25, 2012 | 11:54 PM
I sure hope so.
Old Dec 26, 2012 | 07:21 AM
zenzee's Avatar
ZX-Turbo idles and then dies
You said your fuel pressure is about 50..... what did you measure it with? S-30 and S-130 z car fuel pressure is only approx 37.1, so if you really have 50 it's out of spec and you should be balling smoke out of your exhaust. 50 is definitely out of specs.
mcge8241
Jun 18, 2019 02:47 PM
ptshredder
Jan 31, 2015 10:15 PM
mrprofile
Jan 4, 2011 09:10 PM
Laxguy
Mar 7, 2009 02:09 PM
rlh1
Apr 17, 2001 04:11 AM
