280ZXT Engine Cylinder 2 & 3 Not Firing
Old Oct 3, 2012 | 06:48 PM
Z_lover's Avatar
Okay, so my Z was running fine except for the fact that the injectors were leaking fuel. I replaced all the injectors along with the seals. Now cylinder 2 & 3 are not firing. I placed a voltmeter at the injector connectors and it measures 0.3V (same as the other cylinders). There is spark at both cylinders and compression is good. I checked the dropping resistors for the injectors and they are all at 6 ohms. Any other thoughts on what to investigate?
Old Oct 9, 2012 | 10:29 AM
Z_lover's Avatar
Anyone out there??
Old Oct 9, 2012 | 10:51 AM
Did you pull those plugs to see if they are wet or dry? Maybe the injectors still aren't spraying?
Are the replacement injectors new?
Old Oct 9, 2012 | 11:20 AM
Z_lover's Avatar
All of the replacement injectors are new. I will have to double check if the plugs were wet or not. I suspect the same thing, but how else can I confirm they are working "electrically" speaking? I ohmed them out and they are within spec. I measured the dropping resistor voltage and I measure voltage across the harness going into the injector. Am I missing something?
Old Oct 17, 2012 | 10:27 AM
Z_lover's Avatar
Figured it out. Had a bad electrical connection to the two injectors, but on top of that I one bad injector (one of the new replacement injectors....grrr!).
polonick
Jun 27, 2015 12:06 PM
gojoedobb
Oct 21, 2012 01:15 PM
datsun280zxt
Jan 5, 2012 10:50 PM
MikeZ
Feb 19, 2007 11:30 AM
snwbrderphat540
Jan 19, 2006 10:18 PM
