280ZX Fuel Leak
Old May 10, 2017 | 08:32 PM
TommyBoy's Avatar
280ZX Fuel Leak
Hello,
I recently purchased a 1980 280zx and have found that its leaking fuel. This is my first ever project car and I am a little intimidated by this and kind of just want some advice on how to get this repair done efficiently. I attached some pictures of where I believe the leak is coming from.
Thanks in advanced guys!
Attached Thumbnails 280ZX Fuel Leak-img_0708.jpg   280ZX Fuel Leak-img_0709-1-.jpg   280ZX Fuel Leak-img_0715.jpg
Old May 11, 2017 | 09:44 AM
Welcome to ZDriver!
That's the fuel filter... most likely just a loose clamp or split hose. Time to inspect.
Make sure you download the FSM: http://www.xenonzcar.com/s130/fsm.php it has literally everything you need to get the car repaired properly. And search through the forum for awesome write-ups and how-to's.
Old May 11, 2017 | 11:06 PM
TommyBoy's Avatar
Welcome to ZDriver!
Make sure you download the FSM: XenonZcar.com S130 Factory Service manuals it has literally everything you need to get the car repaired properly. And search through the forum for awesome write-ups and how-to's.
Thank you! I just downloaded and flipped right to it. I noticed that when I turn the car on, fuel begins to pump out the top of the filter, would replacing it solve this issue? The FSM isn't super clear on it.
Thanks again!
Old May 12, 2017 | 06:39 AM
If it's leaking, yes, replace it.
Old May 15, 2017 | 09:08 AM
icice9's Avatar
Super Siver & Black Stud
make sure you change your hoses too while your at it..
Old May 22, 2017 | 02:35 PM
Exactly. Make sure you buy the more expensive fuel hose made for fuel injection.
Don't get low pressure fuel hose made for carb engines.
I just replaced the fuel filter on my ZX. Its a somewhat easy job.
1983Gold
Jun 24, 2016 11:31 AM
d33zdrama
14
Mar 3, 2012 05:15 PM
eZdoesit
Aug 12, 2011 07:17 PM
hoov100
Mar 7, 2010 02:51 PM
cookiecutter
Jun 8, 2003 10:32 PM
