2 questions
Old Jun 15, 2006 | 10:42 PM
skittle's Avatar
Taste My Rainbow
2 questions
ok this is probably in one of the threads and i know i'll get flamed for this but here are my simple quick questions.
1. what size of wrench do i need to adjust my valves?? I have a whole bunch but just not the right size.
2. and what size socket do i need to turn the crank to put the valves pointing up?? I can turn it by using the key and doing short bursts, but i would rather use a wrench to do it.
Thnx Much Guys!!!
Old Jun 15, 2006 | 11:26 PM
"blue's tech tips" i would just bump the starter, i actually once put a socket on the cam and turned it over that way.
Old Jun 15, 2006 | 11:30 PM
skittle's Avatar
Taste My Rainbow
yeah thats what i did at first then found out i did not have the right size wrench to adjust the valves... i need to find out what i need
Old Jun 16, 2006 | 12:08 AM
thxone's Avatar
I used 11/16 and 9/16....but I think they are metric as I had very little play on the 9/16th box wrench.
Old Jun 16, 2006 | 12:25 AM
Thnx Much Guys!!!
Well... I could say:
but I won't. The valve locknuts should be between 13 & 15mm. Hopefully you have 13, 14, & 15mm wrenches?!?! Take off the valve cover, and test which ones fit. If a 13 is too small, and a 15 too big... Wa-La! It would be a good investment to have a complete wrench set from 8mm - 17mm.
Using Standard wrenches on Metric bolts & nuts is a big NO NO... unless it is an emergency. That's how a lot of bolts & nuts get rounded off. Buy a complete Metric & Standard wrench set, so you don't have to fubar a bolt.
Old Jun 16, 2006 | 12:33 AM
thxone's Avatar
Yeah, I know....but visually I can not tell the difference in the nuts between metric and standard. I know the 11/16 fit perfectly and the 9/16 was just a RCH off. But thank you for rubbing in the fact that I am to poor to afford good tools...or the correct tools. J/K, I have my eye on a real nice set O tools, should have them soon...probably before I get my damn Haynes, which they had me re-order.
Old Jun 16, 2006 | 01:20 AM
skittle's Avatar
Taste My Rainbow
yeah i have a set minus the 14 so i guess thats it huh...lol
Old Jun 16, 2006 | 06:53 AM
to adjust valves you need a 14mm and a 17mm, the front pulley is 22mm or 24, cant remember everything
Old Jun 16, 2006 | 08:05 AM
skittle's Avatar
Taste My Rainbow
ok thnx alot...
Bdan57
Feb 5, 2010 12:42 PM
81-280zxnt
Nov 23, 2009 01:24 PM
81-280zxnt
Oct 20, 2009 12:02 PM
SandW
Oct 11, 2006 08:08 AM
pearly whites
Aug 18, 2004 06:20 PM
