1983 280zx turbo problem starting and running possibly fuel
Old Dec 22, 2006 | 08:46 PM
antiman's Avatar
i recently put a new heater core in my car and every since it has had problems running. its like it is flooding itself trying to start and when it does start it runs fine until i change gears or stop itslike any time i let off the gas it has a problem getting back its pressure.
Old Dec 23, 2006 | 11:33 AM
rogerz's Avatar
Grumpy & Helpful
You disconnected something when you did the heater core. Either electrical or vacuum. Probably vacuum since you were in hte climate control system. Generally if it was working and now doesn't it is the last thing you changed.
Old Dec 23, 2006 | 12:02 PM
id say vacuum as well, there is a line that runs through the firewall right near where you are working, its small, but could cause a problem
Old Dec 23, 2006 | 01:15 PM
Possibly knocked loose the CHTS plug....
Old Dec 23, 2006 | 03:48 PM
BigEkak1941's Avatar
I agree about the possibility of disconnecting something. I had a similar problem and found the plug on the side of the engine above the starter was disconnected. Once I put it back it was running like a bat out of Hell. I recommend you check all the plugs (some look like they are connected, but may be loose.). Good luck and have a happy holidays. Sincerely Dan
Old Dec 23, 2006 | 03:52 PM
icice9's Avatar
Super Siver & Black Stud
i agree with NismoPick... the CHTS is right next to the heater hoses on the pass side of the block and can be easly knocked loose from disconnecting the heater hoses..
Old Dec 23, 2006 | 04:31 PM
hey on my p79 head, i took out the sensor cause my 79 doesnt need it, i didnt plug it cause the coolant never came out, its a blind hole! i guess its not a submerson type sensor?
Old Dec 23, 2006 | 06:35 PM
antiman's Avatar
what an idiot
well i honestly deserve the idiot of the year award!!!! i checked the CHTS vacuum lines and all connectors. then low and behold decided to check the spark plugs. well they were shot, bought 6 new ones changes them in 5 minutes(the beauty of an inline) and magic running like a bat out of hell again. thanks to all who gave me there feedback and opinions.
S130Monica
Jan 26, 2015 08:02 AM
jrlogan280z
May 8, 2010 08:23 AM
steveh_131
Feb 23, 2010 08:39 AM
