81 280zx Turbo Fuel Problem, Help?
Old Jan 24, 2015 | 04:06 PM
S130Monica's Avatar
The engine starts and idles fine, but if I turn it off and try to start it again, it runs rich with fuel and will not start. I have to leave it for about a hour before I try starting it again. I've replaced the fuel regulator and still have the same problem. I cant seem to find the source to this problem, any suggestions?
Old Jan 25, 2015 | 01:44 PM
zxguy1986's Avatar
Welcome to ZDriver!
Make sure you've downloaded your factory service manual just to get yourself more info on your 280. It's a freebie at XenonS130 - S130 Reference along with other cool docs. Your FSM is loaded with inspection and troubleshooting pages that are pretty easy to follow, so check those out and see how many of them might deal with your issues at this point.
Let us know what you've tried after that and let the 280 guys give you their input. You can post some pics here too and maybe a bit more of the history of that Z.
Thanks and welcome again!
Old Jan 26, 2015 | 08:02 AM
You sure it's running rich and not lean / no fuel? Have you pulled the spark plugs to verify?
The CHTS and AFM are the two main sensors controlling fuel delivery. Check their outputs (per FSM) and connections for corrosion.
Zeedevil
May 23, 2012 06:11 PM
Kronic_C
Feb 20, 2010 09:13 AM
antiman
Dec 23, 2006 06:35 PM
Barzen
Oct 8, 2002 01:44 PM
