1982 280zx smog failure
My zfailed CA smog I expected this however the guy said the timing was at 16 and it needs to be at 8 I ordered a timing light and it should be here next week howeve I have no clue on how to adjust the timing can someone help???
Haynes manual ...
FSM ...
Our search feature ...
Click: https://www.zdriver.com/forums/showt...ghlight=timing
FSM ...
Yes, bringing the timing back for some reason cleans up smog a bit.
I think for your car 8-10 is good but for emissions checking go on the conservative side. 7-8 BTDC is great.
For driving you may find that moving it back up to 12 before gives you a bit more torque once you have passed smog.
you can also try SeaFoming it stuff works amazingly just pull a vac line that sucks (make sure its not the one to your brake booster) shove the hose in the can and rev the car. if the car dies its not a problem pull the hose out of the can start back up and rev higher lol hope this helps
Ok turned the timing down to about 7-8 then went for my free retest and I still failed the hydro carbons aloud is 138 I got 249 at 15 mph and aloud at 25mph is 77 I got 210 any thoughts on why this could be ?
HC means it's either running too rich, or the cat isn't working.
Was the car at running temp for the test? Does the car have a cat? Is the motor stock?
And read this in its entirety: https://www.zdriver.com/forums/showt...ghlight=failed
The engine is stock as far as I'm aware I was driving it around all day so defiantly at operating temp And it does indeed have a cat
Do u think I should try unplugging one of the injectors?
decided that my smog numbers were two high to go and do the retest so i ordered a new cat it will be here friday will probably put it on over the weekend break it in then smog it on my day off next week
If your # 6 cylinder has good compression. Unplug # 5 with your new cat set your timing to 5 degress, and unplug your cold start valve. Also make sure your oil and filter is fresh, and your car is freshly tuned up. Good luck man. I feel for you.
280ZXfan
Feb 19, 2011 10:10 PM
Nissan4Ever_626
May 31, 2008 08:47 PM
