Why not use exahust bolts instead of studs and nuts
Old Aug 15, 2013 | 07:15 PM
davidjoe007's Avatar
Hi Everybody... I was just checking out Shady280's how to do your intake exhaust gasket. I need to replace my gasket and I'd like to do it soon. So...
I was thinking why not do bolts? I know nuts strip and that would be a nightmare. I know some nuts seize, also a nightmare.
The studs look tricky to take out. BTW are the studs reverse thread or regular?
Has anyone ever tried this? Any downsides to doing all bolts instead of studs and nuts?
Anyways... I look forward to everyone's thoughts on the matter.
Dave
Old Aug 15, 2013 | 10:34 PM
Here is a link to how to change your intake / exhaust gasket by Shady280
https://www.zdriver.com/forum/240z-2...gasket-18779/0.
Old Aug 16, 2013 | 06:56 AM
Because studs have better clamping force than bolts. The same reason head studs are better than head bolts. If you've had nuts strip, it's because they were either cheap grade (Home Depot style) or over-torqued. You should use a high grade stud for the exhaust manifold studs as they are repeatedly subjected to heat cycles. Napa and/or your local fastener warehouse will have them.
Also, the studs make it much easier to install the exhaust manifold since you can hang the manifold on the studs.
Not tricky at all. Lock two nuts together at the end of the stud, then use a wrench on the inside nut to back out the stud (just like a bolt head).
Old Aug 16, 2013 | 05:36 PM
Thanks Nismopick.
Old Aug 18, 2013 | 08:54 AM
second what nismopick said. thanks for reading my how to!! the other important part is to use those factory thick washers to spread the load out between the manifolds. regular washers just dont do the trick
Old Aug 19, 2013 | 11:53 PM
Twiggs280zx's Avatar
Here is a set from Motorsport
Motorsport! Manifold Bolt, Nut & Stud Kit, *75-83 280Z/ZX - The Z Store! Nissan-Datsun 240Z-260Z-280Z-280ZX-300ZX(Z31/Z32)-350Z-370Z Parts
Old Sep 16, 2013 | 04:53 AM
^ I got that same exact kit for my '82 slicktop, when I did the cylinder head. You can't beat the factory set.
Crashcourse
Jun 24, 2015 08:34 AM
omniserv
May 23, 2011 08:09 PM
KeithDigital
Jul 8, 2009 08:49 AM
tonsoffun300zx
Oct 27, 2007 11:22 AM
GARYZ240
Feb 4, 2005 12:43 PM
