Valve Adjustment tips for a 1983 280zx
Old Apr 25, 2013 | 01:27 PM
RETICON's Avatar
Question Valve Adjustment tips for a 1983 280zx
Hey folks,
So I'm getting a clunking noise and took it into a shop for it to be examined, they said the valves need to be adjusted.
I'd like to do it myself (I want to learn more about the car and more about mechanic work for it)
If you were talking to a total newbie (Even though I'm engineer), what would you recommend, what processes and what tools will be required.
My car is: 1983 Datsun 280zx NON TURBO - digital dash model, it has the overhead cooling unit on the engine, so I believe it's an L28?
Old Apr 25, 2013 | 01:38 PM
Click:
https://www.zdriver.com/forums/280zx...ed-help-36212/
https://www.zdriver.com/forums/280zx...jusment-35135/
Old Apr 25, 2013 | 01:44 PM
RETICON's Avatar
AH! GENIUS!
Is there anything I should look out for or be aware of when I conduct this. This will basically be my first time doing anything like this.
Old Apr 25, 2013 | 01:53 PM
Have a note pad handy so you can check off the ones you've done... that way you don't have to second guess your work.
Before doing any adjusting, check the specs as they are... that way you know at the beginning if there are any out of spec.
If they all need to be adjusted, adjust cold, replace valve cover, get up to operating temp, then adjust hot (you'll need some paper towels and leather gloves). Loosen all pivots at the beginning so you can go through them all more quickly.
The first time can feel sketchy... 2nd time is cake. Just follow the procedure EXACTLY as outlined in the FSM / Haynes.
EDIT... and make sure upon completion that all rocker springs are lined up correctly and secure.
Old Apr 25, 2013 | 01:59 PM
RETICON's Avatar
Thanks for the tips!
How do I 'check the specs' on the engine? I see it outlined in the paperwork but is there any lamens terms explanations for how-to? Because If I'm to follow EXACTLY to spec, I need to make sure what I'm doing is right for a newbie.
Old Apr 25, 2013 | 02:03 PM
You use the feeler gauges. Insert feeler between cam and rocker, it should be able to slide all the way in & out with just a bit of tension on it.
Old Apr 25, 2013 | 03:01 PM
RETICON's Avatar
Perfect! I'll go purchase one a feeler gauge kit. Know of any places (in California) that sell it? Pep boys?
Old Apr 26, 2013 | 03:48 AM
Gonzo's Avatar
Feeler Gauge
OReilys or Autozone should carry them but you'd have to look yourself because nobody knows what they are anymore. Ask and you'll get a dumb stare back. I bought mine at Harbor Freight for about $2.00
WanganDevilZ
Jul 30, 2012 07:07 PM
fatman
Apr 19, 2012 08:38 AM
BlueKitsune
Jun 13, 2009 02:51 PM
Soup80
Dec 27, 2003 10:33 AM
jtmny1999
Mar 26, 2003 11:08 AM
