turn key...vroom...brbrbrbrrrr...dead...turn key...vroom...GOOD.
Old May 5, 2005 | 08:20 PM
juggalo280ZX's Avatar
about 40% of the time when I start me 280ZX, it starts fine and right away and everything, but then it slowly dies like its not getting enough fuel or something, but second start works perfect every time. any one else have this problem and/or know why and how to fix?
Old May 5, 2005 | 09:19 PM
DynamicJ's Avatar
Z8 driver
haha, thats probably one of the most creative thread titles I've seen... I'm not sure, but you could try adjusting the air fuel ratio screw... i did that on mine, about a half turn, and it made my Z idle at a higher RPM, and NEVER died anymore... There is a thread about it somewhere. I think Icice9 took a pic of where it's located under your hood.
Old May 5, 2005 | 09:56 PM
Blah! Mine did that for years and it went away. Just flutter the throttle gently after you fire it up the first time. mabye it was bad contacts on the throttle position switch.... brrrrrap... bap..bap..caugh..choke hack brapp VROOOOOM... GOOD
Old May 5, 2005 | 10:21 PM
duckyz's Avatar
Mine did that so bad that it finally stalled out and wouldn't start again. I yanked the ECU and cleaned the contacts, put some of that die-electric grease on it....16.95 completly stock. No complaints here.
However-- You might want to look at your cold start valve too. The Haynes guide has step by step instructions as how to test it.
Old May 5, 2005 | 10:27 PM
Thanks guys, I'll look for that thread, and the 60% of the time when it doesn't die is when I succesfully "work" the throttle and make my girl roar!... you know I mean the car...right.
Oh, about the tittle, It's like a gift...you know... I just let those vioces come out and talk on occasion, and sometimes it can turn out catchy, other times it's like, um...ok.
Old May 6, 2005 | 06:30 AM
DoTheDrew888's Avatar
When you go to start your car, turn the key to the position before the start position and let it sit for a second. That will let the fuel pump charge the lines. When you hear the fuel pump stop, try starting the car. Also, change your fuel filter.
Old May 6, 2005 | 07:52 AM
s/cL3.0's Avatar
Bleach is my Hero
Do you notice if the oil pressure light is on?? Mine does the same thing when its time for an oil change..
Old May 6, 2005 | 08:03 AM
I haven't noticed the oil presure light being on, but it could probably use a change. Thanks again.
300zgearhead
Oct 9, 2011 11:48 PM
gdcat51
Jun 27, 2009 12:15 AM
theramz
Dec 3, 2007 02:43 PM
eric489
Jul 31, 2002 11:45 AM
orngxtc
Aug 13, 2001 01:08 PM
