turbo vs na transmissions
Old Dec 7, 2003 | 10:07 PM
kansaskeith's Avatar
What are the differences (if any) between the turbo 5 speed transmissions and the na 5 speed transmissions?
Old Dec 7, 2003 | 10:37 PM
craZed's Avatar
not sure .IF U DONT HAVE ONE ALREADY U SHOULD DEFINATLY GO TO AUTOZONE OR WHERE EVER AND GET YOURSELF A HAYNES REPAIR MANUAL .IT WILL ANSWER YOUR QUESTION HERE .AND HELP IN THE FUTURE.AT LEAST W/ THE HOWTOS
Old Dec 7, 2003 | 10:40 PM
thanks, and yeah your right i need a manual, but i just recently bought my z this week, it runs well besides the throwout bearing, not bad considering it came with another body which is rust free and has a turbo motor and all the electronics, including digital dash. All for the low low price of $262
Old Dec 7, 2003 | 10:46 PM
craZed's Avatar
SWEAT DEAL. WHAT IS RONG W/ TURBO CAR THOUGH ,DOES IT HAVE GOOD TITLE 2? MIGHT WANT 2 DITCH THE DIDGY DASH THOUGH
Old Dec 7, 2003 | 10:49 PM
the turbo car has an automatic transmission, but origianally had a manual and all the stuff like clutch pedal and stuff are still there so the auto will come out and the manual will take its place, yeah it doesnt have a title but that will be taken care of, and yeah i prefer the analog, so ill prolly just sell the digital dash cuz their rare and i know someone wants it.
Old Dec 16, 2003 | 09:31 PM
duckyz's Avatar
The n/a turbo should do just fine unless you're going for a real "hot rod". If so, Bleach could tell ya.
Old Dec 16, 2003 | 09:33 PM
duckyz's Avatar
What an idiot I am....The n/a tranny would work just fine.....geez.....where's my friggin' brain?????
Old Dec 17, 2003 | 10:39 AM
Those old Nissan automatics are not that good. The internals suck power and the gearing is less than ideal plus they top out in 3rd gear at 1:1 ratio. Think about driving your 5-speed around all day in 4th gear.
Late model cars however seem to have appropriate gearing and much better shift points in their automatics. (I compared the Altima auto and 5-speed. I got the auto)
for anyone who likes an auto but wants more power, get the 1983-84 Nissan maxima 4-speed auto. its 4th gear overdrive is a taller gear than even the non-turbo 81-83 280ZX! (which is the tallest 5th gear avail for a Z) Put a 3.9 or 4.11 rear in there and you'll still be under 3,000 rpm at 70mph while in overdrive.
One guy on this forum put the 4-speed Maxima auto in his 280ZX turbo and I think he runs a 3.9 rear.
"for those that don't know, the Maxima up to 1984 has the L24 so the 4-speed in that car is for an L-series engine"
Old Dec 17, 2003 | 03:42 PM
TheeZ's Avatar
Coming to understand "Z"
the turbo and n/a trannies are the same. the trannies changed with the years not the models. The rear end is a diff. story tho. The turbos had a higher geared rear end for a higher top end, cause they had the power. N/a s had a lower rear end to boost power..
Old Dec 17, 2003 | 09:15 PM
icice9's Avatar
Super Siver & Black Stud
there is a diffrence with the n/a and turbo tranny the turbo ZXs used a t5 W/warner..a lot heavier then the n/a tranny but a lot more durable.. also it uses a larger fly wheel and it has a diffrent throwout bearing carrier... IMO id get the t5 B/W tranny if your going to put a 5 speed in your turbo ZX... you can pound on it a lot harder then you can with the n/a 5 speed
Old Dec 18, 2003 | 07:22 AM
Where did you hear that the T5 is heavier? I have one and it is aluminum! That thing is so light weight. I don't have a Z 5-speed out, but I do have an old 4-speed and the 4-speed weighs a lot more than the Borg Warner T5.
I've also heard people say the n/a tranny is stronger than the T5 but I'd guess they're not totally right. The n/a tranny is strong enough for most turbo L28 applications.
Old Dec 18, 2003 | 08:06 AM
icice9's Avatar
i know from experiance that the t5 is heavier... ive replaced clutches for both n/a and turbo cars and yeah the t5 was a lot heaver to work with... the n/a tranny was a lot easier for me to lift in place while the t5 really beat me up..
Old Dec 18, 2003 | 04:47 PM
TheeZ's Avatar
doh forgot bout the t5...
the bw didnt come on all the turbos tho did it? thought it was 83, but im still learnin..
i haven't felt the t5 but the standard tranny is pretty light, doesn't it have an aluminum case? i put in a r200, i think the diff. weighed more than the tranny, but maybe it was just the size that threw me off, whew..
Old Dec 30, 2003 | 11:53 AM
Lazerus's Avatar
The T5 is a sturdier tranny and it has slighty different 1st and 2nd gears (if i remember right). If I was doing the swap I would go with the T5, mostly because there are several readily availably upgrades for them.
Rrassi300zx
Mar 26, 2013 08:30 PM
jessezx
Dec 5, 2009 10:46 AM
PurePontiacKid
18
Oct 31, 2009 11:16 PM
Bleach
Other Cars
Jul 17, 2008 02:51 PM
kwiknez
Mar 14, 2002 07:17 AM
