transmission removal help 5 speed
Old Oct 18, 2009 | 01:59 PM
tmcharper's Avatar
i removed 3 bolts so far, 3 to go. any hints on how to remove the two on the top of the tranny? also do i have to remove the driveshaft or will it just slide out when the tranny drops down?
Old Oct 18, 2009 | 04:52 PM
For the top two, get a 14mm box wrench & use a pipe as an extension (usually you need to press on it from the side to get it going). And yes, take out the driveshaft.
Old Oct 18, 2009 | 04:56 PM
If you got some *****, you could have a friend unbolt it, while you hold it up and bring it down ontop your chest, then just wrestle it to the side.
(did a T56 (90 pounds) in a camaro this way once)
Old Oct 18, 2009 | 04:58 PM
^^^ yeah... that hurts.
It won't just fall off when you unbolt it. Two people man-handling it is advised...
Old Oct 18, 2009 | 05:30 PM
BlueKitsune's Avatar
Intrawebz Wizard
I've done that with my Z! And I'm about to install it that way too @.@ Those top 2 bolts are easy to get to with the VC off
Old Oct 21, 2009 | 07:03 PM
rogerz's Avatar
Grumpy & Helpful
about 3-4 feet of ratchet extension and a universal will get those bolts out. Helps to have someone up top guiding but I've done it alone at the junkyard.
Old Oct 22, 2009 | 06:35 PM
i use a ratchet wrench once the bolts are broke free, the trans wont just fall out, i usually leave the x-member in while undoing everything. then pop it out and just wrestle the trans out. i can have a L series out in 30-40 minutes. 2 ppl can be helpfull for the removal, but it can be done alone. you can also jack up the back of the trans to tilt the assembly fwd and up to give more room to those top bolts
Old Oct 22, 2009 | 07:01 PM
tmcharper's Avatar
flywheel help
thank you for your help with removing the tranny, now i need advice on holding the fly wheel still so i can remove the bolts holding it on! any help would be aperciated.
Old Oct 22, 2009 | 07:13 PM
Impact gun... seriously. They are torqued to 100ft/lbs+.
Old Oct 23, 2009 | 08:42 PM
tmcharper's Avatar
throwout bearing cilp
any one have a pic of the clip (Spring) placement on the throwout bearing and fork clip (Spring) I popped them out in not so much light and now I'm having a tough time trying to figure out how they are supposed to go back!
any help would be appreciated.
Old Oct 23, 2009 | 08:52 PM
Intrawebz Wizard
I put a tranny bolt back on the block and a bit Flathead screwdriver in the teeth of the flywheel to hold it still, then I used a 4 foot breaker bar. If its still in the car, put a socket on the front pulley bolt so the crank wont turn over.
Old Oct 24, 2009 | 08:12 PM
FubarI33t's Avatar
i did the flywheel by hand. sure i used a cheater bar. but it was PVC. i put a socket on the front crank bolt. it spun around till it found a frame rail. and boom your in business
Old Oct 24, 2009 | 11:51 PM
It goes in the slits in the fork... there's only one way it will sit proper. You're not doing this w/o a Haynes manual or FSM are ya?
You can download the FSM at www.xenons130.com/reference
Old Jul 14, 2011 | 02:26 PM
Samuel Lewis's Avatar
I have removed all the bolts securing the the transmission to engine. When I when to pull the transmission back far enough lower and remove the transmission, I could not. Which the clearance, I found the potion of housing which holds the starter hits the body preventing me from moving the transmission back far enough the the engine spline shift. Please instruct as how to move the engine back far enough to remove.
Thank-you
Sam Lewis
Old Jul 14, 2011 | 06:05 PM
evandubya's Avatar
Primer Grey FTW!
You are suppose to remove the starter.
Old Jul 21, 2011 | 10:17 PM
He means the bump the starter hides behind. You can spin the tranny to clear that bump once your clear of the dowel pins. The exhaust may also be in the way. Depends on your setup there
Old Jul 22, 2011 | 08:47 PM
duckyz's Avatar
^^ Yeah. Three bolts and the exhaust is free.
Old Mar 18, 2013 | 07:03 AM
tamug92's Avatar
Good time to replace oil pan gasket and rear main seal
I'm guessing that while the tranny is off it would be a good time to replace the oil pan gasket and rear main seal if necessary? I need to replace my oil pan gasket and started out by doing it the way shown in the Haynes manual but that sucks. My rear main is leaking anyway so I plan on just replacing the oil pan gasket and rear main with the tranny off. Anything to look out for?
Old Mar 18, 2013 | 07:52 AM
The oil pan gasket is quite a job in-car. We've discussed it a few times here, but with the transmission out, it should be easier to remove. I believe the other hard part it getting to the bolts directly above the motor mounts. Some have said that using an engine hoist to lift it an inch will help.
Old Mar 18, 2013 | 06:21 PM
PredatorZ's Avatar
ya
Been there done that, having a Trans Jack is so much easier, but ya, if your tuff, but the reverse process isn't as easy, but doable.
zenzee
Sep 1, 2012 10:01 AM
79fairlady280
Jun 29, 2009 01:08 PM
BackHouseZ
Apr 30, 2008 05:57 PM
bluesman1958
Apr 15, 2004 03:31 PM
shanedog
Nov 5, 2002 10:53 AM
