Top Speed?
Old Jun 22, 2005 | 09:45 PM
  #76
DoTheDrew888's Avatar
I was following my friend in his Prelude the other night. He said he was going a little over 140 mph. My car was over 5000 rpm in 5th gear and he was slowly pulling away from me. I figure I was doing about 138 mph. Not bad considering that theorectically I could keep accelerating until I reached 6500rpm.
My car is an '83 modified N/A 2+2. I also had the T-tops off but I think I had the windows up, I can't remember.
Old Jun 22, 2005 | 11:14 PM
  #77
assimilated420's Avatar
well i have redlined my car with my 3 speed and on the transmisson calulator it tells me 136, but i dont think it factors turbo, or the fact i have the boost increased..
Old Jun 23, 2005 | 03:18 PM
  #78
jfairladyz's Avatar
How much does that sucker cost? That sounds pretty damn neat.
Old Jun 25, 2005 | 07:15 AM
  #79
texaz42's Avatar
The Garmin unit with the maps and gps sensor cost about 130 at Best Buy.
Old Jun 25, 2005 | 01:14 PM
  #80
jfairladyz's Avatar
Thats nothing. A Gtech is somewhere in that range anyways, and the Garmin unit sounds better to me for not much more $$$. I'm gonna have to check that out. Does it come with the sensor or do you have to buy it seperate?
Old Jun 28, 2005 | 07:14 PM
  #81
texaz42's Avatar
No, the garmin comes with the maps for your computer, plus all the add ons like stores, gas stations, restaurants,, etc... with the phone numbers. The GPS sensor just plugs into a usb port and runs off the computer power, and the cord is about 6' long so you can put on your dash, or wherever you want. You can also plan a trip and put in your fuel mileage, and it will tell you when and where you need to stop for fuel. A totally awesome package.
Ive also used mine for plotting out land, and it will tell you acreage.
The only problem, using the laptop is kinda bulky on the motorcycle, but works great in cars.
Old Jun 28, 2005 | 07:31 PM
  #82
jfairladyz's Avatar
Now thats the S#!t !! I'm getting one of those. I drive cross country quite a bit(not usually in my Z though) so that will help me out a lot. I won't have to pay so much attention to maps and stuff like that. And for only $130. That's alot of features for only $130.
Old Jul 4, 2005 | 10:45 PM
  #83
280ZX_AV8R's Avatar
I shall have my 130mph speedometer in the next week or two. then i can safely say my top speed.
Old Jul 5, 2005 | 02:08 PM
  #84
jfairladyz's Avatar
120 passing 3 tractor-trailers on Hwy 83 north through Nebraska on my way home from Co. Keep in mind this was in my 1981 280zx non turbo, which only has a 4speed transmission. The gears in the tranny are the same as the 5speed, except I don't have 5th. I hit that speed at about 5500rpm's+. The car was still pulling, but like I said earlier, I wasn't trying to break any records. Just trying to pass a few trucks before another car comes flying over the hill. RPM's may not be exact, but pretty close none the less.
Old Jul 5, 2005 | 02:10 PM
  #85
jfairladyz's Avatar
Oh, and the speed was verified by my brother in his mustang as he followed in pursuit and called my cell phone while passing and said "dude, we're doing 120!" My speedo is the 130 unit, but is severly in need of calibration, or more likely just a different speedo gear. It says I'm doing 95 when I'm actually only going 70mph.
Old Jul 6, 2005 | 08:59 PM
  #86
280ZX_AV8R's Avatar
The other day me and an 180-pound passenger figured we were going about 120 at about 5400rpm (using the odometer and figuring how many miles we can go in one minute) so since I can safely go all the way to 6250rpm, I figured I top out with only me in the car at around 130-140mph . But I will have to see when I get my 130mph speedometer.
Old Jul 6, 2005 | 10:27 PM
  #87
lww's Avatar
lww
Head Muckraker
Yes, you have the wrong speedo gear. I would bet you have a gear for the 3.545 diff and you actually have a 3.90 diff.
What do you think? And ask me how I know this...
Old Jul 6, 2005 | 10:47 PM
  #88
lww's Avatar
lww
Head Muckraker
Why settle for a 130mph speedo?
Old Jul 7, 2005 | 03:49 AM
  #89
Are you serious lww? That says 210mph not kph? Wow if so where did you get it from?
Old Jul 7, 2005 | 04:20 AM
  #90
Pistolio's Avatar
thats the exact same speedo thingy that i got in my zx! EXACT!
my one is in kph thow
Old Jul 7, 2005 | 08:44 AM
  #91
lww's Avatar
lww
Head Muckraker
This was originally from Canada and came as a 210 kph speedo.
A little blackout and re-calibration and it's now a 210 mph speedo!
Old Jul 7, 2005 | 10:17 PM
  #92
jfairladyz's Avatar
Anyone know which speedo gear I need then. And how do I verify what ratio I'm running out back. Do I have to scrape all the sludge off my diff in hopes of finding a number or can someone tell me based on my VIN?
Old Mar 13, 2006 | 10:13 AM
  #93
PooFlinginMonke's Avatar
It's 136mph where the limiter kicks in.
You can change base timing on a 1981 280zx turbo by using the screw on the crank trigger which is made for adjusting timing.
Old Mar 13, 2006 | 10:37 AM
  #94
Actually the 280zx's didn't have a speed limiter. nor rev limiter for that matter....
Old Mar 21, 2006 | 03:07 AM
  #95
frank280zx's Avatar
Euro Z King
From: Utrecht The Netherlands where owning a car is a CRIME!!
My NA 2+2 eurosec does 245 kmh on a gps ( eurospec, but with 11:7.1 compression, fully worked head)
Stock Turbo ( eurospec 2+2) does 268 KMH ( they have a standard 3.3 gearing and .85 AR exhaust housing etc.
BTW euro speedos go through 240 KMh and turbos to 260 no miles stated so a clean look !
Old Mar 21, 2006 | 06:20 PM
  #96
I Can Get 240 Kph No Prob, But The Speedo Cant Go Faster, I Need A G-tech Pro, And Some Major Open Smooth Road.
Old Mar 21, 2006 | 06:36 PM
  #97
I have a vid somewhere on one of my tapes of my Canada Z's speedo on the freeway. Looks a lot diff than the US version... kinda looks like ya goin a lot faster than ya really are.
Sometimes I switch my parent's 03 Buick LaSabre gauges to metric & watch their eyes light up when they start the car... he he!
Old Mar 21, 2006 | 07:58 PM
  #98
lww's Avatar
lww
Head Muckraker
The G-Tech is not so good for measuring top speed in high speed runs. Speed through the traps on a 1/4 it can handle.
You need a GPS or a GPS based data acquisition system although a normal GPS that calculates MPH/KPH will work just as well, but you figure you'll spend about the same on just a GPS as you would a full blown GPS data acquisition system!
The Racepak G2Xtreme is only $899 at: http://www.g2xtreme.com
And was rated by the SCCA's official magazine "Sports Car" as the easiest data acquisition system to install and use...
Old Mar 21, 2006 | 08:16 PM
  #99
Or Ill Just Go To My Buddies In The Force And Get A Radar Gun
Old Mar 21, 2006 | 08:57 PM
  #100
jfairladyz's Avatar
Or you could have somebody with a 160MPH speedo in their European super car tailgate you during your topspeed run
