Temp gauge suddenly not working
Old Jun 27, 2005 | 12:49 PM
davidjoe007's Avatar
Hi Everyone,
I was working in the motor compartment changing some old fuel lines and then adjusting the timing...everything going smooth... The car is warm by now... I took a look at the gauges and the temperature gauge had no reading. I think a loose wire in the motor compartment but couldn't find any loose wires. Any suggestions.
Old Jun 27, 2005 | 02:26 PM
Check your fuses, if that is good, check your temp sensor, and also the plug that goes into the front of the engine. I found out before when I was running my Z, and the temp was not working. I looked under the hood, and found a loose plug in front of the engine. Jiggled it around a bit, and the temp gauge worked again. Just had to secure it with another clip that goes around the plug itself. Hope this helps you out! And again glad to hear you got another Z, good luck to you!
Old Jun 28, 2005 | 11:17 AM
thanks
Thanks... the coolant temperature sensor right above the thermostate housing was loose.
Thanks again... it great to be driving a Z again. 83 t-tops baby.
Old Jun 28, 2005 | 01:43 PM
Right on man glad I could help you out. Anyway that is a sweet Z bro'! Take care of it, and get a good decent alarm on it.
Old Mar 7, 2023 | 09:28 AM
Z you later's Avatar
Dave,
Where in the Bay do you live?
I'm in San Mateo.
280Zx Turbo 5 speed.....appreciate my Z and others.
BADASSTT
Jun 21, 2009 10:23 AM
82zxturbo
Oct 30, 2007 09:28 PM
pmr2000
Mar 14, 2006 09:49 AM
Heat Rave R
Apr 15, 2005 04:58 PM
RED-Z-1
Aug 14, 2003 11:46 PM
