Stock fuel rail
Old May 28, 2021 | 10:18 PM
andyb's Avatar
Stock fuel rail
Is there a max flow rate for the stock fuel rail? what cc per injector do i need to replace the stock rail? I have ~370cc injectors, no fuel pump yet.
Andy
Old Jun 2, 2021 | 11:12 AM
The fuel rail can flow all the fuel you throw at it. The real limiting factor is the fact that it's "barbed" and 99% of all modern fuel injectors are 11mm or 14mm o-ring style. You can try removing the rubber o-ring from the fuel injectors and clamp them on like barbed, but they will inevitably leak as they are not designed to be used in such a way (leaking fuel on hot engine = fire). This is the reason people go with a Pallnet or ProTunerz o-ring fuel rail.
datsun280zxt
Jan 18, 2011 03:03 AM
drtask
Apr 4, 2009 12:51 PM
skittle
Jan 9, 2007 08:09 AM
SHADY280
Mar 8, 2006 04:30 PM
SHADY280
Jan 1, 2006 11:29 AM
