sputter and backfire
Old Mar 28, 2003 | 11:40 AM
lifegrddude's Avatar
Externally Wastegated
Also check for vacuum leaks and leaks in the exhaust system from the manifold back if the above doesn't pinpoint your problem. There are a couple other things to look for, but for now it's probably best to start small and work to bigger.
John
Old Mar 28, 2003 | 12:49 PM
Could very well be ignition timing or your vaccume advance not working properly. Valve timing could be a small part of it as well.
Ignition timing is not hard to fix. just look at the distributor, see that the rotor has proper play and snaps back like it should. Adjust it with a timing light. Should just be in the center of the manual adjustment if everything else is ok. For the valve timing, you need to replace your timing chain and other components. A timing set will give you the timing chain, chain guides, chain tensioner, two sprockets, and possibly a crank bearing. Set the new chain/upper sprocket at position #2 for better low end torque.
JT1237
Aug 29, 2014 04:30 PM
eishiba
20
Jul 3, 2014 09:21 AM
SebastianPavich
Jan 24, 2014 06:58 AM
morbidrazor
Jun 5, 2011 09:17 PM
Monkies
May 23, 2011 10:51 PM
