Recurrent No Spark
Old Jul 27, 2013 | 06:05 PM
campfirestring's Avatar
Recurrent No Spark
For the second time in a year I'm left with a no-start/ no-spark situation.
the first time, it was the Ignition Control Unit which is screwed onto the side of the distributor. Now, I'm not sure that's what's broken this time, but it might be.
I've replaced within the year:
-all high tension wires
-Ignition coil
-spark plugs
-Ignition Control unit
I tested for spark on the primary HT wire before the distributor... and nothing.
Besides something wrong inside the distributor, what could cause recurring shorts or failing ignition electronics?
Old Jul 27, 2013 | 07:09 PM
rogerz's Avatar
Grumpy & Helpful
poor battery and battery cables. wiring chewed by rats, mice or squirrels. ignition switch. ecu
Old Jul 28, 2013 | 07:04 PM
well it looks like it's the ignitor, again. I would like to be sure though. I went through every test in the FSM and at the end it said something like, "if all these tests are okay, replace the IC unit." Is there any test I can do to be positive that the unit is bad? these things aren't cheap and there's no 280zxs in the junkyard around here.
what would cause one to go bad so quickly? i just replaced it last year.
Old Jul 28, 2013 | 08:02 PM
rogerz's Avatar
Grumpy & Helpful
look on the net for how to test a transistor with a VOA. that is all the ignitor is - a power transistor. probably anyone would work that could take the current. they are pretty rugged if you put in a new one I would doubt it was bad or something is wrong in the circuit that caused it to fry.
G30
Oct 14, 2014 03:54 PM
Fairladyz1990AF
Apr 24, 2014 04:15 PM
KSpakes87
Feb 7, 2013 03:30 PM
wirestrecher
Dec 30, 2010 05:30 PM
z4doug
May 21, 2005 05:43 PM
