rebuild of 82 280zx l28na proformance
Old Oct 25, 2007 | 06:47 PM
Jadon's Avatar
the main bearing spun on my engine so i know i have to do a rebuild. but since it has to go into a machine shop, i was wondering, what kind of things i could do to upgrade some torque and horsepower. like boring out and how much should i do. and up grade the cam? i have never done a rebuild on this kind of engine before but i am ready and excited. i am taking pictures and pulling the engine out now. so basicly what kind of stuff can i do to make it better?
Old Oct 25, 2007 | 07:36 PM
It depends on how much money you have to spend and what your hp goal is. Post those & we'll go from there.
Old Oct 25, 2007 | 07:47 PM
Jadon's Avatar
ok well. i really badly want to do a rb25det but i dont want to spend that much money and some other problems. but i want as much power i can and still keep around $1000
Old Oct 25, 2007 | 07:49 PM
Jadon's Avatar
or what would you do in my shoes? just find a parts car with maybe a turbo? i dont know. it's not going to be my daily driver. just a fun weekend car.
Old Oct 25, 2007 | 07:54 PM
You'll never get as much power from an n/a as a turbo. You can spend $1k and have ~170whp on an L28, or 210whp+ w/ an L28ET. The L28ET is a torquey monster too.
Old Oct 25, 2007 | 08:07 PM
Jadon's Avatar
ok, well should i rebuild and use the money getting the items to make it turbo? im intimidated by the wiring problems i hear. should i be? should i really just uy a doner car?
Old Oct 25, 2007 | 08:25 PM
Gear's Avatar
always research my friend, great book at msa for performance and also rebuilds on these engines. i just accquired my first z and started work, this site and the books were awesome for getting me startred
Old Oct 25, 2007 | 08:26 PM
entropy31's Avatar
The Cake Is A Lie!
if you have the NA motor rebuilt, you would want to put in lower compression pistons. might as well just get a turbo motor. easiest way to go, and usually the most cost effective.
Old Oct 25, 2007 | 08:27 PM
Jadon's Avatar
ok, thanks guys...
Old Oct 25, 2007 | 08:35 PM
thxone's Avatar
$1,000...Nitrous baby....have the switch mounted under the gas pedal so it only kicks in under full throttle, this way you can drive and have good gas mileage and then POWER when you need it. Just have them put some forged pistons in it with good rings.
Old Oct 25, 2007 | 08:42 PM
entropy31's Avatar
The Cake Is A Lie!
banned!!!
Hum... $700 for forged pistons + $200 machine work = 150hp motor that can take 10 second 100 shots of nitrous now and then... that's a great equation.
Old Oct 25, 2007 | 08:46 PM
thxone's Avatar
Other than the fuel starvation it sounds like a good idea to me.
I guess you could add secondary fuel injectors to compensate right....he did say $10,000 is his limit right?
Old Oct 25, 2007 | 08:50 PM
$900 for the option of 100 shots of nitrous, until the bottle is empty... then you get to refill it. I'd rather spend $900 and have the power available ALL the time... but I guess I'm too picky.
Old Oct 25, 2007 | 08:51 PM
One too many zeros mi laddie:
Old Oct 25, 2007 | 08:54 PM
Spraguepsycho1's Avatar
Fuel starvation should only be a problem if you used an old school style dry system. Wet system adds the needed fuel with the nitrous when set up properly and is actually fairly safe on most engines. I'd still go with a running turbo donor car instead if one could be found for $1000 or less, and just do a complete swap, engine, trans, and rear diff.
Old Oct 25, 2007 | 08:58 PM
thxone's Avatar
Ok, in reality though you don't "need" the power "all" the time right...so why destroy the fuel economy? You can have a stronger bottom end, 25-29mpg and 250hp when you need it. I don't know about you but that sounds pretty good to me. Sure it cost a bit but if you are not using the nitrous "all" the time it should last...self control man. I am just talking practicality man...I think N2O could be the way to go in an L28 engine. I am not trying to say it is for everyone but it isn't a bad option when you give it at least some thought. How many of you are driving around in second gear with the gas pedal floored constantly with 12psi pumping through the engine...nobody, you kick it in when you need it.
Old Oct 25, 2007 | 09:00 PM
thxone's Avatar
I know...I was being silly...I am not a noob....or Snw...give me SOME credit.
Old Oct 25, 2007 | 09:01 PM
It would be a pain here where I live unless I could find a local medical supply place to fill the bottles. The nearest speed shop to me is right around 125-150 miles away. I'll stick with mechanical boost lol.
Old Oct 25, 2007 | 09:49 PM
Ok, in reality though you don't "need" the power "all" the time right...so why destroy the fuel economy? ... self control man.
Going by your own "self control" idea... you should already know that if you don't full throttle the turbo, you'd be getting that same (or close to same) fuel econ. And I thought you liked turbos:
https://www.zdriver.com/forums/showt...t=22728&page=5
I just took it around the block...HOLY SHEET ***** FOOCKA!!!!! IT IS FAST...FAST I TELL YOU and sounds so fookin sweet...SWEET I TELL YOU!!!!!! I am in the Boost!! I AM SO HAPPY!!!!!!!! No misses all the way to 6,000rpm!!! I am good...with your alls help of course.
Twiggs280zx
Mar 31, 2016 09:57 AM
accord_raffi
Mar 5, 2009 01:23 PM
onerudebuddha
FS: 300ZX (90-96)
Sep 23, 2007 12:48 PM
fairladyVT
Mar 16, 2005 03:31 PM
Tony G
Jul 22, 2003 12:54 PM
