Question about turbo sounds
Guest
Posts: n/a
Awhile back I posted message here about my 280zx (https://www.zdriver.com/showthread.php?t=7185)
I have tried most if not all of the suggestions and my car still sits. While looking around on the net I found a similar problem and the guy said that his turbo made a wine when it was running. Mine did this too, some people said it was normal and others said it ment the turbo was dying. What is it supposed to sound like? When I drove mine it sounded like a cop siren. Is that bad? Thanks for any help.
Is it a whistle almost? Turbos do whine when they spool up they make a distinctive noise. If it extremely loud you could have excessive shaft play. if it is almost a whistling sound your turbo may be near seizing which would restrict air going in the intake side of the turbo and restrict exhaust gases leaving which would make a whistleing noise with the limited amunt of air getting in and out (like when you clasp a leaf and blow on it almost)(does oil leak out at the intake side or exhaust side of the turbo?). It might just be that the turbo was also run to hard and it overheated and fried (no water cooling).
There are a number of things but its hard to tell it might be best to check out the turbo.
Guest
Posts: n/a
turbo...
I would say it was almost a whistle, It was pretty loud but I haven't heard any other turbo charged car. When I first drove the car as a test drive and the turbo spooled up I thought the cops where already bugging me. The car is messed up now, and I think its the turbo, the mechanics in this town didn't do anything for it. Whats a good way to test the turbo? And if it is the turbo does any one know where I could find a replacement that doesn't cost a few thousand?
turbos make a nice whistling sound but it shouldn't be an ear splitter. You might want to take the turbo off and examine it and get it checked out you can have it rebuilt if its necessary. It should only cost a few hundred for a new turbo if that or you could get it rebuilt they aren't to expensive stock.
Guest
Posts: n/a
about the turbo
There are some odd things going on about that car. As said before when you rev it up it sputters and stalls. It keeps doing this untill you let off the gas. If you press the gas slowly it takes a bit more time.
All that was known.
I found out that if its sputtering and someone pulls open the Emergency release valve, it will work. Any ideas on that?
Also, I heard that in order to test if the problem is the turbo, I need to run it with the wastegate open. Where is the wastegate and how do I open it? Sorry for all the questions, I'm not much of a car guy and the mechanics here don't do their job too well.
All that was known.
Turbo sounds
Not long after I got my car I had a loud whislte under boost and the hose from the turbo to the J pipe had a split in it. Then a little later the a similar noise started and I found the turbo to manifold nuts loose making it whistle. As for the emergency relief how do you pull it open, are you sure thats what it is and not the egr. It has a bov(blow off valve) but it is sealed and you cant get a finger on it, unless yu have an aftermarket of some type. The waste gate is attached to the turbo housing and has a vacuum line attached to a servo with a rod coming out of the middle going to the waste gate. You should check it and be sure its opening and closing properly and not binding or froze............
The turbos in my car sound like a siren at the right RPM. If the turbo was hammered, it would most likely howl like a banshee if there was excessive shaft play, or it would not make any whistle sound if it was seized. Either way, it's a wild goose chase. Does the car run ok if you slowly rev it up, or does it just run a bit longer before dying? The whistle sound you're hearing, does the pitch or tone change as you increase the RPM's, or does it remain constant? Check all of your grounding points to make sure you have solid grounds. I'm assuming you've changed plugs/wires/cap/rotor. Have you checked the hose between the MAF and the throttle body? Make sure you don't have a crack in that. If you did, then the more the engine moved under torque, the more the crack you open. This could cause your problem. Check all you vacuum lines too.
If your Z is sputtering like that, it could be the fuel system or ignition. Is the AFM in good shape? Has the fuel filter been changed? Are all the injectors okay with none leaking? On my ZXT, when the turbo spools, it sounds like when you let air flow past your teeth, almost as if you were trying to whistle through your teeth. Anyways, if you're in the San Diego area, I don't mind trying to help you out.
John 82ZXT
John 82ZXT
Guest
Posts: n/a
Thanks for the help
I still don't have it going, we rechecked the fuel pressure, its okay. My dad put a tester on a line somewhere and said the turbo wasn't putting out much of anything. Does anyone know a good way to test the turbo without taking it to a shop?
Thanks for the help offer but I live in Trinidad Colorado, If there is anyone around there I'll gladly accept help.
Also I'm not sure on how to check the Distributor. The AFM has been changed.
The lighter you are on the gas the better it does, but it still messes up.
I don't know if its important but this didn't just happen. It would mess up a little bit when I started it and first started going, then after some time it would just do it once in a while, Then it started doing it all the time. I hope that helps with trying to figure it out.
Thanks again for all the help.
Yank off the rubber hose that goes to the turbo and see if the compressor blade has any shaft play. You can check inside the j-pipe after the turbo to see if maybe oil is getting into the intake system. You don't have vacuum leaks do you? Just curious cause it will cause your Z to sputter like crazy. Biggest culprit for me was those small hoses that attached to the vacuum pump for the a/c system. That and the PVC valve hose.
John 82ZXT
John 82ZXT
How did your dad check the output of the turbo? A turbo won't register much output unless you're driving it. Just revving the car up in the driveway won't really do anything. What does you boost gauge read? I think it's a fuel issue. Possibly not enough fuel pressure. Have you tried checking the ECU fault codes?
