o2 sensor WELDED ON.
Old 06-27-2012, 06:14 PM
campfirestring's Avatar
I don't know what to think. it appears that the person who swapped out the exhaust manifold for headers really screwed up the o2 sensor. it appears do be welded into my exhaust headers... but I could be wrong.
obviously, when headers are fabricated for this car, the o2 sensor needs a hole to screw into. These things screw in, right? I've looked at loads of pictures of them and they appear to have a hex head and threads, so it makes sense that they would just screw right out. Who would have the knowledge to build freaking headers and then do something as stupid as welding it on?
I've soaked it in WD-40 and wrenched on it but nothing. what do you guys think? I just want to make sure that it definitely screws out.
campfirestring is offline
Old 06-27-2012, 06:38 PM
Cut it off, grind up the area to make it smooth, weld in new oxygen sensor bung and installed new oxygen sensor.
hoov100 is offline
Old 06-27-2012, 06:45 PM
bung, eh?
will a big nut work? (hehe) i suppose it has to be air-tight.
Old 06-27-2012, 06:51 PM
77280ZX's Avatar
what hoov100 said. its the best way.
77280ZX is offline
Old 06-27-2012, 07:18 PM
I can't seem to find a specific o2 sensor bung for this car. Can it be researched according to the correct sensor?
Old 06-28-2012, 08:50 AM
^^^ First Google result:
Discount Nissan 280ZX Oxygen Sensor Autopartsdeal.com
18 x 1.5 mm thread size
O2 Oxygen Sensor Nut Bung 02 M18 x 1.5 THREAD | eBay
I've welded in several of those bungs... works like a champ!
NismoPick is offline
Old 06-28-2012, 09:14 AM
perfect nismopick! exactly what I was looking for!
Old 06-30-2012, 07:07 AM
that actually is screwed into the o2 bung in your picture. get a 18mm box end and try or a pipe wrench, betcha it comes out, that said its probably just as quick to install a new one.
SHADY280 is offline
Old 06-30-2012, 09:48 AM
ThaPimpShrimp's Avatar
If you're replacing it anyway, I just cut the wire off of mine so I could fit a socket around it easily. Also get some PB Blaster (or WD 40 if nothing else) and spray it a couple times a day and then try.
ThaPimpShrimp is offline
nick731
05-08-2012 07:38 AM
dankfrye@charte
09-17-2011 09:11 PM
iHeartTouge
02-15-2007 07:32 PM
n00blar
05-13-2006 05:47 PM
rewplayff
08-26-2004 11:38 AM
Quick Reply: o2 sensor WELDED ON.
